installing steam line, questions..
Old Jan 6, 2012 | 02:12 PM
LVZ2881's Avatar
Default installing steam line, questions..
Any tips or tricks to install this so it doesnt leak. motor is out of car. I have the new washers with the rubber insert. I noticed when it ook it off there were no washers just brass washers and it didnt leak.
Old Jan 6, 2012 | 06:03 PM
94fixerTA's Avatar
I noticed that too when I did mine. I haven't started mine yet to test for leaks but I did it the way it was on shoebox with the rubber washers.
Old Jan 6, 2012 | 06:33 PM
LigHtEmUp01's Avatar
buy the factory washers from a dealer and put gasket sealer around them and make sure theyre tight
Old Jan 6, 2012 | 07:07 PM
Spartan7's Avatar
GM seals x4. I didn't use any sealant, just some anti-seize on the bolt threads. You have to really crank them on there too. Not enough room for a torque wrench, but spec is 30 ft. lb.
Old Jan 7, 2012 | 12:11 AM
LVZ2881's Avatar
Thanks for the advice guys. I always seem to forget shoebox's site. Motors out of the car, so I will be able to torque them down.
Old Jan 7, 2012 | 01:31 PM
RamAir95TA's Avatar
You could convert to AN fittings and lines if you wanted to.
Old Jan 10, 2012 | 07:32 PM
mooseknuckles's Avatar
any more info on this?....pics?
Old Jan 10, 2012 | 07:55 PM
Sc0tt30's Avatar
Here is a link to a thread by gregrob on how to do it
https://ls1tech.com/forums/lt1-lt4-m...onversion.html
Old Jan 10, 2012 | 08:04 PM
Z28Z06's Avatar
Anybody have the SHbox link or pictures, also interested. I'm doing a LS-1 to LS-6 intake conversion.
