AC delete with engine in car
Now I just need to relocate the alternator and get rid of the ABS block, then hide all the wires with the next build.
I also kept the vacuum line so I can still switch the airflow to head, feet, or defrost.
After all the cutting
With the panel to re-route airflow in place
All finished up
Close Up
My other question is how did you attach the panel
http://ltxtech.com/forums/showthread...-heater-ANYONE
The UMI panel is made to be installed from the inside of the car. I had to trim one corner a little to make it fit on the engine side of the firewall. I used all the same bolts I removed from the HVAC box. There were a few holes that I had to get creative with and used some fasteners from the local hardware store. I cut an oval hole for both the heater core lines to pass through. Behind them I used some HVAC foam from the hardware store to make a gasket with plenty of RTV to seal everything up air tight.
