Front Control Arms
Old Jan 11, 2012 | 03:02 PM
earlz28's Avatar
Default Front Control Arms
Anybody know where I can get some replacement A-arms for the front end? Ball joints that come pre-installed would be a welcomed bonus.
Thanks!
Old Jan 11, 2012 | 03:26 PM
pillarpod's Avatar
http://www.umiperformance.com/catalo...Path=7_137_103
Old Jan 11, 2012 | 03:31 PM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
All our a-arms come with ball joints installed and ready to go. Here is a quick link to both our regular tubular a-arms and our 1" lowering a-arms.
AA002 - Tubular lower a-arms
AA020 - 1" Lowering tubular a-arms
If you have any questions let me know and I will answer them.
Kyle
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Jan 11, 2012 | 03:45 PM
earlz28's Avatar
Is there an OEM replacement option? Money is tight!
Old Jan 11, 2012 | 03:48 PM
draggin97s10's Avatar
if money is tight do bushings and ball joints. Are you sure the ball joints are bad and not just the upper and lower bushing. Did you check the ball joints with the jack under the control arm?
Old Jan 11, 2012 | 03:54 PM
earlz28's Avatar
Yes both bushings and joints are bad, it's not in the budget to upgrade the arms so you're saying I'm better off just replacing those?
Old Jan 11, 2012 | 03:57 PM
BMR Sales2's Avatar
Unless you can find a set of a-arms at your local junkyard your best bet is going to be to replace the bushings and ball joints in your current a-arms. Both Prothan and Energy Suspension makes replacement bushings and you can get a ball joint from your local auto parts place.
__________________
Glenn ***
Sales Tech
813.986.9302
Old Jan 12, 2012 | 09:14 PM
earlz28's Avatar
Thanks fellas
Old Jan 13, 2012 | 09:26 AM
jaycenk's Avatar
Unless you are looking for more road vibrations to be transfered into the steering wheel and the car, stick with the stock style replacment rubber bushings. I have pollys and I hate them. Usless unless you are racing. And by the way Stay the freak away from the TRW ball joints. Go with moog. TRW lower ball joints screewed up both front lower control arms when I had a guy at the local Chevy dealer try to press them in. Turns out that even thought they make what is called an oversized lower ball joint, even the "standard Size" is over sized and he ended up bending both lower control arms. Buy Moog or the Napa quality brands to replace that stuff. I had to replace both lower control arms due to TRW's lower ball joints being to big to fit the socket.
Old Jan 13, 2012 | 09:32 AM
earlz28's Avatar
Thanks for that additional info Jaycenk, I went to my advance auto and got moog prices on everything.
Old Jan 13, 2012 | 05:39 PM
jaycenk's Avatar
Old trick you could try IF you are doing the lower ball joints you self is to freeze the ball joint and heat the control arm socket and see if they will drop in. I am not sure I would recomend using a press while the control arm is heated since there seems to be a risk of bending them. You might get luckey and it may drop in or be able to be taped in with a rubber malet.
If you do them your self you Might want to get some advise from any members here that have done them their selves. I bought replacments for the replacments at napa as well as new stock control arms and the guy at the chevy dealer said they went in easier this time when he pressed them in.
Old Jan 13, 2012 | 07:38 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Find a shop that does suspension work and have them press in the bushings and ball joints.
The forward bushings must be pressed into the same depth as the original. IOW, if the bushing is pressed until it's flange is up against the control arm, you've gone too far.
Old Jan 13, 2012 | 08:27 PM
earlz28's Avatar
I wasn't going to press them myself but Ill be sure to pass this advice on to whoever will be assisting me, thanks
