how can i change governor
nope. send it to pcm for less or someone qualified. if you buy a tuner and start messign with stuff not knowing what it does, it gets real expensive real quick, and you wont have a engine to salvage anything from
You need more than a scanner, you need something to edit the pcm flash memory, a scanner only reads codes.
If you want to DIY your best bet is to buy the Tunercat software/cable. The cheapest route will be to remove your PCM and ship it to someone like pcmforless for programming.
