Help with mild LT1 build!
Did you miss the mild part?
Why not just do a damn compression and leak down and go from there?
Too many assumptions that the engine "must" be worn out with that mileage.
FWIW I would consider replacing rod and main bearings if a compression test is within spec. There are engines that go over a million miles and never lose ring seal, but they do like fresh bearings every once in a while.
.02
If going through the hassle of rebuilding it, why not just pull the slugs out and then determine the condition of the bores. Wait no I love to have to crank the engine over to check each bore....
And no I didn't miss the mild part... did anything i mention get into great detail with the engine????
