Help with mild LT1 build!
Hey guys, me and my friend are working on a 95 z28 bone stock 180k miles! The car is getting paint as we speak and then we are going to pull the motor. He ran 14.0 last year with nothing but mid lenght headers ( I told him to get LTs but he didnt) He wants to get this thing in the mid 12s at lest.
Some questions...
Heads, can we use stock ported, LT4... what are some cheaper options?
Cam... what would be a good streep/strip cam
intake... stock ported, LT4?
Going to run true duals off the mid lenghts, he wants to keep them.
I figure at lest a 3000 stall and the car already has some set of unkown gear in it. Its toped out in 3rd at the strip. Any input would be great. Also we might just buy a freash LT1 instead of a rebuild if anyone has anything. Thanks guys
Some questions...
Don't bother with the lt4 stuff. Keep the lt1 stuff and get a heads and cam package from one of the sponsors on here like ai or le. 3000 stall is a good all around size if the car sees street driving pretty often, although you may want to go bigger depending on your cam. Going to need tires and suspension as well.
So boltons, h/c, stall, suspension, and sticky tires should easily be in the twelves.
You don't need any headwork to get into the mid 12s. A mild cam such as the popular XE503 can get you there easily with bolt-ons and good tuning/suspension.
Thanks guys, the motor is going to need a rebuild so I was thinking just do new bearings and rings. Throw a cam in it, rebuild the heads with a litttle porting. Not sure how much he wants to spend yet, what about the intake manifold and throttle body.... Any solid gains that can be made there?
With that many miles I'd be willing to bet the block is going to need to be bored, so at that point I'd buy a set of forged pistons and a set of Scat Pro Comp I beam rods with ARP 2000 bolts, turn/polish the crank with new rings and bearings and the cam of your choice. New timing set and all new gaskets and if you have the skill or the money I'd have the heads ported add a stall and at least 3.73's and you'll easily reach/exceed your goals.
You'll definitely want these two things due to the difficulty in correcting later or failure at higher power levels.
1. Forged pistons
2. ARP Rod bolts
3. Stock crank (not some POS aftermarket $200 crank)
Everything else can be corrected later (heads work, cam, etc.).
Also, if this is also a driver, don't go to crazy on the camshaft. Head work will actually pay off more than a huge cam on the street.
None of it will work right without a proper tune.
1. Forged pistons
2. ARP Rod bolts
Just going to use stock crank, arp rod bolts and have the rods done should work. Were not planning on big power, we just need to be able to drive it to the track, make some runs and go home. He won't be driving the car daily or anything. Forged pistons would be nice, hopefully the crank looks good and this thing don't need to much work. First step is tear it down, if the motor looks shot would it be worth a ls1 swap instead? He said he would be happy with around 400 flywheel for now, he has been out of the game for a long time LOL.
Did you miss the mild part?
Why not just do a damn compression and leak down and go from there?
Too many assumptions that the engine "must" be worn out with that mileage.
FWIW I would consider replacing rod and main bearings if a compression test is within spec. There are engines that go over a million miles and never lose ring seal, but they do like fresh bearings every once in a while.
.02
Lol OK... I know exactly what you're getting at and anyone competent could determine bore symmetry, taper, and piston to bore clearance with the slugs in place.
.02
.02
