Value of a stock LT4 block
This is completely aside from the straight vs. splayed argument, big power means aftermarket caps no matter which way the outer bolts run.
Then again with the cost of a build that warrants 4-bolt what is a couple hundred dollars anyway?
I should have quoted Jerry Clayton too as I think he has it right, leave them for the Vette guys.
And yes, save the untouched LT4 block for the vette guys doing a restoration or something.
There is, however, a difference in a LS1 and LS6 Block. The LS6 block has different webbing in it to vent PCV better, and other small suttle differences with the Oiling from what I have read.
and just to add to that convert a 2 bolt thing there is actually quite a bit of work to be done......caps have to go in the bridgeport and be machine to fit the saddle correctly then it has to be line bored/honed.....so id does cost some money.......
tony i saw one sell on ebay for 700 a few months back.....seems like factory 4 bolts are becoming kinda hard to find....
