Header Gaskets
Old Jan 17, 2012 | 07:52 PM
StraightTimeStirrups's Avatar
Default Header Gaskets
How many of you run header gaskets or go without any and just use Copper RTV?
If you use a Gasket which brand do you prefer and the same question for RTV?
What size/length header bolts do you guys use? I've heard that they need to be longer then the SBC bolts!
This will be a 95% track car by the way.
Joe
Old Jan 17, 2012 | 09:06 PM
RamAir95TA's Avatar
Anyone who tells you to use RTV instead of gaskets is a plain moron. Overall a bad idea.
Use Felpro 1406s, dry.
For header bolts, you'll find all kinds of different opinions, but mostly it depends on your headers and how much clearance you have to work with the primaries. However the only thing we can all agree on is that you'll want to go with a 1" bolt wherever possible (again, depends on the headers you have).
Old Jan 17, 2012 | 09:32 PM
I have had friends racing for 30 plus years and not use gaskets but it just doesnt seem right to me to be honest. Just looking for opinions!
Joe
Old Jan 17, 2012 | 09:35 PM
cammednasty's Avatar
go with the felpros
Old Jan 18, 2012 | 12:39 AM
rich5368's Avatar
Felpro 1406 and standard off the shelf small block Chevy header bolts from autozone here.
Old Jan 18, 2012 | 01:05 AM
lt1slowz28's Avatar
this.
Old Jan 18, 2012 | 01:16 AM
Zlow28's Avatar
are those bolts the same as oem or are they weaker/stronger?
I just unbolted my exhaust manifolds and i had 1 bolt break in the process. Maybe it was my fault, but id like to know if there are any other stronger bolts out there.
Old Jan 18, 2012 | 01:53 AM
gregrob's Avatar
Joe
No problems with no header gaskets, I go without them all the time. You can also just get gasket paper from the parts store and cut gaskets out of that, or use sand paper. It lasts much longer than normal header gaskets such as the "fel-pro 1406" junk...
I would just get some wood screws at Lowes to hold the headers on.
Old Jan 18, 2012 | 02:10 AM
What grit? Wet and Dry or Emery Cloth?
Old Jan 18, 2012 | 02:14 AM
gregrob's Avatar
60 grit dry. Brah
Old Jan 18, 2012 | 02:15 AM
6.0L mustang philly's Avatar
i say super glue or gorilla glue with a lil duck tape for header wrap to keep under hood temps down
Old Jan 18, 2012 | 02:17 AM
gregrob's Avatar
Dont try and side track him here, I'm really trying to help. I used to make and sell custom sandpaper head gaskets down south and that **** was rowdy. Usually picks up a few tenths due to increased scavenging, and they will last longer than the headers themselves.
You can coat them with a little turpentine to help them stick.
Old Jan 18, 2012 | 02:20 AM
Catmaigne's Avatar
Nah, just use some caulk. That way you won't even need bolts.
Old Jan 18, 2012 | 02:21 AM
Robmamba's Avatar
Spray it. Then replace it..... Then use the sandpaper to clean out the headers?
Old Jan 18, 2012 | 02:22 AM
gregrob's Avatar
Dont have any pics but you just make an outline of the flange on the sand paper and then cut it with a utility knife.
Old Jan 18, 2012 | 02:24 AM
Robmamba's Avatar
Ok. last question. Will LT1 headers Fit my LS7?
I mean it has a L in it so it should work right?
What Grit sand paper?
Old Jan 18, 2012 | 02:26 AM
gregrob's Avatar
No they wont fit unless you modify them.
60 grit FTW
Old Jan 18, 2012 | 10:51 AM
katz_2003's Avatar
[QUOTE=gregrob;15853724]No problems with no header gaskets, I go without them all the time. You can also just get gasket paper from the parts store and cut gaskets out of that, or use sand paper. It lasts much longer than normal header gaskets such as the "fel-pro 1406" junk...
Felpro 1406s are junk??? Guess I like junk then cause these gaskets are prolly the best I've used. I've never had any problems with them what so ever! Anyways...if you use arp bolts make sure and get the 5/16s headed ones. The 3/8s work fine but are a SOB.
Old Jan 18, 2012 | 11:10 AM
I knew I would get some comedians with this one but you guys came up with some Larry the Cable Guy responses, lol!
I am off to get some 1406 Felpro's! I will look for the right bolts or just go by some 12 points!
SS RRR's Avatar
Village Troll
Joe
Race what?
Pay no mind. It wasn't but a short while ago he was all over this forum asking what header gaskets to use because "omg i just got branny new hedderz1111..."
