translator plus?? WTH is it and what does it do
Old Jan 23, 2012 | 09:36 PM
chevylt1camaro's Avatar
Default translator plus?? WTH is it and what does it do
i got a device call translator plus by horsepower in a box. i have no clue what it is or does no intructions came with it apart of the deal i got with the car help would be appriciated thanks.
Old Jan 24, 2012 | 06:48 AM
bowtienut's Avatar
It modifies the output of the MAF sensor to trick the PCM into thinking there's either more or less air intake. So you can use it to modify WOT A/F mixture. The same thing that is accomplished by editing the MAF tables via Tunercat, Tunerpro, LT1Edit, etc.
MAF translators were popular a long time ago before the tuning software became cheap.
Old Jan 25, 2012 | 06:07 AM
ok thank you, is it worth putting it in or selling?
Old Jan 25, 2012 | 06:16 AM
bowtienut's Avatar
It's not much use unless you can datalog with a wideband O2 sensor.
Sell it if you can and apply the funds toward a custom tune, preferably a dyno tune.
Old Jan 25, 2012 | 06:52 AM
moehorsepower's Avatar
As said ^, but good luck trying to sell it. If you ever get a tune, the tuner "Should" calibrate the maf anyway if needed and this is rarely and area that needs to be altered. Most in FI applications but not N/A..
Old Jan 25, 2012 | 10:19 AM
96capricemgr's Avatar
Those are best left to vehicles without much aftermarket support. The car you have is HEAVILY supported by the aftermarket.
Basically what I am saying is they have their place but here is not it.
Old Jan 25, 2012 | 07:55 PM
ok thanks i was plannin on dynoing the car anyways sometime this summer if i have the funds
