93 z28 m6
Old Jan 24, 2012 | 09:32 PM
silver1r's Avatar
Default 93 z28 m6
I am gonna be buying my 93 z28 that I built when i was 18 back from a buddy of mine. It has a 383 with le1 heads and cam and full bolt ons. It has the m6 and it won't go into forth so im gonna go into it and replace the 3-4 shift fork and put a stage 2 kit in. Now, if I remember right, the 93 m6 is different from the 94+. Is that correct? And if so, what is different? Can I buy a stage 2 kit for a t56? Thanks
Old Jan 25, 2012 | 12:49 AM
93Z2871805's Avatar
Veteran: Air Force
I'm pretty sure the M28 and M29s were T56s just with different gear ratios. MN6s were 94+. What are the RPOs on your car? Do you have GU2 or GU4?
Old Jan 25, 2012 | 07:27 AM
silver1r's Avatar
I will have to check when he gets it out of storage. Thank you for the info
