Speed density my only option with my setup?
Old Jan 26, 2012 | 10:11 AM
05HD's Avatar
Originally Posted by gregrob
Ive been running SD on mine for months and yes it does vary.
Change elevation 1,000+ft or let the temp swing 50 degrees and I notice a big difference in how the car runs and it always corrects the WOT AFR too much in situations like this.
I don't have a bunch of LT1 specific speed density experience but you may have a trim or a constant out of whack on your tune. It could even be something you can't see with your definition file. My stock speed density '93 doesn't do that and neither does any other speed density platform I have experience with. If there is a quick, radical change, it may need to get a new key on engine off baro reading but that is about it.
Old Jan 26, 2012 | 10:22 AM
gregrob's Avatar
This is on my LS1 car
Old Jan 26, 2012 | 10:39 AM
05HD's Avatar
Something is definitely up then.
Old Jan 26, 2012 | 11:00 AM
gregrob's Avatar
Whats up is that speed density varies whether people want to believe it or not. A lot of guys who pay close attention to their tunes will tell you that.
Also you can talk to a lot of well-respected tuners who are NOT on the speed density band wagon.
Does it have its place? Of course it does, but not on a mild street driven setup IMO.
Old Jan 26, 2012 | 11:43 AM
05HD's Avatar
Meh, I tend to believe GM over well respected tuners. They have cranked out plenty of speed density vehicles with no issues. I own 2 of them currently.
Old Jan 26, 2012 | 12:52 PM
gregrob's Avatar
Never said they had "issues" I said the tunes fluctuate.
Old Jan 26, 2012 | 01:02 PM
quik95lt1's Avatar
just food for thought....neither a mass air meter'd car or a SD car have a way to measure air density........its a calculation made between incoming air and temperature......on key on engine off the baro re-calculates to atmosphereic pressure which gives a baseline whether its 100kpa at sea level or 95kpa up in elevation.......so the only variable between the SD and MAF tune is the lack of the MAF sensor giving and accurate measurement of actual incomming air........if the VE table is correct it will work just as well.....but if the VE table is off even a small amount < 3-4% it will not run correctly in all types of air even with the system in closed loop......
Old Jan 26, 2012 | 01:07 PM
gregrob's Avatar
VE table was perfect in my app. Tuned it with a wideband and auto ve with all corrections turned off. I spent half a day making sure the VE tables were perfect.
Old Jan 26, 2012 | 01:23 PM
quik95lt1's Avatar
huh.....yea thats what i did too.....u saw the pic i put up lol.......wonder why then......only issue with SD can be low speed drivability around idle speed/kpa because there is no load indexing on the LS computers.......my fast xfi runs load indexed mode off of the TPS also and its by far the best SD tuning platform ive ever used.....
Old Jan 26, 2012 | 01:28 PM
gregrob's Avatar
EFI Live has a TPS VE Custom OS that is supposed to work awesome. I would try that but putting a maf back on the car completely transformed it. It just doesnt need SD being near stock.
Old Jan 26, 2012 | 01:37 PM
djm_e22's Avatar
Well I get my cable in Friday. I have read and still am reading about how to tune. Hope you all don't mind me asking questions as I go through this tuning for the first time.
Old Jan 26, 2012 | 01:38 PM
  #32
Wicked94Z's Avatar
pm me your email address and I'll send you a decent tune for this setup
Old Jan 26, 2012 | 02:47 PM
  #33
05HD's Avatar
Heh, if it wasn't an issue, we wouldn't be talking about it!
You are running corn on the LS1, right? How did you account for that in the tune?
Old Jan 26, 2012 | 03:19 PM
  #34
quik95lt1's Avatar
in EFI live there is a target stoich parameter in the injector tab you can change to make that easier......just fyi lol
Old Jan 26, 2012 | 03:25 PM
  #35
05HD's Avatar
I know that. I also know that isn't the only adjustment that needs to be made to make the car run right *all the time*.
Old Jan 31, 2012 | 10:40 PM
  #36
gregrob's Avatar
91 pump gas
