1994-1993 swap..need input
Old Jan 28, 2012 | 08:10 AM
trilkb's Avatar
Default 1994-1993 swap..need input
Right now i have a 1994 trans am t-top w/125k, It has some nice frame/pinch weld damage that i overlooked when i got it and would like to strangle the ******* who smiled and claims they didnt know...
I found a 1993 PPM camaro z28 Hardtop w/104k for relatively cheap. Its in good condition. PPM is getting rare these days as well. My issue is that ive put alot of money into my 94 and was planning on swapping everything into another car.
As alot of you know 1993 is speed density, 1994 is MAF. If i do swap engines, should i leave the 1993 speed density? Im not sure if anyone would want a roller Trans am thats hurt. But i Think i could make alot of money selling the 1993 Engine and trans and various parts off of the car. Or i can just start a new build on a lower mile engine and sell what i can from the 1994. I would take my headers and exhaust for sure.
I might even need to swap transmissions? not sure if a 4l60e will work in that car or if i would need to use the 1993 transmission, its a 700r4 isnt it?
My concearn is tuning, just getting the hang of tuner pro for the 1994, can you self tune a speed density car? need a chip burner i assume.
Heres the damage to my 94...My main complaint is that this car will never be worth any money with this damage, and it will cost the cost of a new car to fix.... The 1993 however should be worth something in the end since its not damaged, and it has PPM and hardtop going for it.
It also has damage to the dog leg that was poorly repaired. And yes, the car has 2 rocker panels on it!! a 60 mile ride on a crotch rocket after work wears you out enough to over look this stuff. If i had saw this i wouldve said hell no!
Old Jan 28, 2012 | 08:20 AM
trilkb's Avatar
Another option is to just sell the 1994 whole. Do you think its worth money? it runs and drives, its not exactly street friendly untill it gets a better tune. I was planning to do wideband this weekend and start tuning it more, but this 1993 came up.
Old Jan 28, 2012 | 08:27 AM
whytryz28's Avatar
If you do change it over keep the MAF, being able to tune your own cars is easier than messing with a stupid eeprom chip.
Old Jan 28, 2012 | 08:41 AM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
What is PPM?
Old Jan 28, 2012 | 08:53 AM
bowtiedad_z28's Avatar
PPM is exterior color Purple Pearl Metallic which i am kinda partial to.
Old Jan 28, 2012 | 09:35 AM
TeeTopZ's Avatar
Swap everything from the 94. Engine, harness, pcm, 4l60e, and maf. Then you can still tune yourself instead of burning chips. Sell everything else for parts.
Old Jan 28, 2012 | 10:43 AM
trilkb's Avatar
I looked at the car, Im looking at 2000$ right now. Im gonna make a new post because it needs so much work that im at a loss of what to do and more people look at those posts then a technical post lol
Old Jan 28, 2012 | 10:49 AM
VinR1's Avatar
PPM TA below
I vote swap everything over and sell me the 93 harness
Old Jan 28, 2012 | 12:04 PM
colt_impala's Avatar
Not to hijack, But I'm in a similar spot after totalling my 94 after hydroplaning and taking out a fence. I can get a 93 roller for a decent price, but how hard would it be to use my 94 harness? I have little to no experience with wiring. I'm not sure if the 93 I looked at has a harness or not
Old Jan 28, 2012 | 04:59 PM
trilkb's Avatar
^ sounds like its pretty easy, just swap everything you can and you should be good.
I think you need to run a wire to the ALDL if you want to tune though. someone else had a thread on that, not sure if it was completed.
Apparently the harness and computer will swap over easy, youll need to take your trans with you, trans wireing harness. Your o2's as well i think since they are heated.
thats what i learned in a couple good threads. looks like im not going that route anymore though
Old Jan 28, 2012 | 06:49 PM
93z28de's Avatar
Default hay
trilkb what state you in ? i would like to have that shell
Old Jan 28, 2012 | 09:47 PM
trilkb's Avatar
My trans am Shell?
Old Jan 28, 2012 | 10:30 PM
i'm sticking with stock tune. the car i'm buying doesnt have a harness for the motor so for sure i'm using all my 94 stuff. could you provide a little more detail about the trans harness and 02 sensors? the roller and my current 94 are both 6 speed. Wasnt sure if you were refering to my old 93 mentioned in my garage section. that car was sold to (kilgothephenom).
Old Jan 28, 2012 | 11:20 PM
FAD2BLK93's Avatar
swap it all over and sell the shell it will be a great project for the winter months
By Brett Foote | 2026-06-04 05:00:17
