What to look for in a coil? milliamps? peak voltage?
I know, I'm beating a dead horse.
But I have to ask, 7.9 amps from a coil?!
http://www.summitracing.com/parts/PNX-D3002/
Primary Resistance 0.310 ohms
Maximum Voltage 45,000 V
Turns Ratio 100:1
Secondary Resistance 6.8K ohms
Inductance 3.1 mH
Peak Current 7.9 amps
Spark Duration 1.5 mS
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Turns Ratio 100:1
Inductance 3.1 mH
Turns Ratio 100:1
Inductance 3.1 mH
Turns Ratio 100:1
Inductance 3.1 mH
Did you ever get a different coil? I have two of the newer MSD sealed units(one used, one new pn8226). I run a Pro power off a 7AL-3 now. I also have an Dig 6(older model, used pn6520) and the Dig 6AL(new model, never used pn6425) for the LT1.
Yea I don't think so. Looks like a stock one to me. No way that could support that amount of amps.
One of the MSD reps recommended the Dig 6AL with the Blaster HVC coil.
I haven't done anything yet cause I'm in no rush.
No. Never changed it. The plan is to swap in autolite AR104's gapped @ .050 with a hotter coil. The Crane coil I have is crapping out and had to decrease the plug gap to stop it from misfiring at high rpm. It worked but I know the bigger the gap the better.
