Is there a reverse lockout on an M6?
Old Feb 1, 2012 | 09:41 AM
Rob94hawk's Avatar
Default Is there a reverse lockout on an M6?
Thought there was a reverse lockout on the M6. Was cruising along and went too far over when shifting into 5th and bumped the reverse gear slightly. I've never done that before so was just wondering if it might have been disabled by accident. Thanx
Old Feb 1, 2012 | 10:17 AM
ahritchie's Avatar
Yea, both my 6spd 94 formula and 99 firehawk have a reverse lockout
Old Feb 1, 2012 | 10:34 AM
Rob94hawk's Avatar
That's what I thought. Thanx. Just downloaded TunerProRT. Once I get the cable I'll have to see if this can tell me if it's been disabled or not. Why this would be disabled I have no idea. Unless I have a bad solenoid or something.
Old Feb 1, 2012 | 10:37 AM
OnyxY2KSS's Avatar
It is possible to overcome the reverse lockout solenoid with enough force.
Old Feb 1, 2012 | 10:38 AM
stuart4185's Avatar
prolly a bad solenoid if this is the first time you noticed it. it is possible that you incredidible hulked it past too and didnt notice. its just a deterrent, not a lockout.
Old Feb 1, 2012 | 10:49 AM
SS RRR's Avatar
Village Troll
Possibly disabled. Make sure it's plugged in.
It's the brass solenoid attached on the left of the shifter housing.
Is it a different PCM? Could be from an auto car. The plugs for the 1-3 skip shift and RL on the harness are basically the same. Make sure those aren't mixed up.
Old Feb 1, 2012 | 10:52 AM
Rob94hawk's Avatar
It's the same pcm. Will check it out with my next oil change. Thanx
Old Feb 1, 2012 | 12:31 PM
guppymech's Avatar
The reverse lockout solenoid is engaged when it has no power. The pcm powers the solenoid to unlock the reverse gate with the engine running and the speedometer below like 5 mph. Above that speed or with the car off the lockout is engaged. The lockout is only an increased spring load to get into the reverse gate...try it with the car off, you should have to push fairly hard to get into the reverse gate. I let my brother drive my car once and he upshifted from 4th to reverse.
