Made my own custom intake (Large pics)
After reading several intake threads on here, and looking at pics of your setups, I decided to piece together a custom CAI.
![](http://img361.imageshack.us/img361/3415/firebird004.jpg)
![](http://img51.imageshack.us/img51/4690/firebird003.jpg)
![](http://img380.imageshack.us/img380/5884/firebird002.jpg)
![](http://img72.imageshack.us/img72/7750/firebird001.jpg)
I thought about doing the LS1 lid, but I figured I should try my own.
The SOTP meter seems to tell me I did good.
And I didn't have to trim the core support or the underside of the hood.![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Total cost was about $100, and I could have spent less.
I do wonder if i need a radiator cover, as I don't think its going anywhere.
dont forget to reconnect the smog pump hose that is just laying there. If you dont have to worry about emissions then remove the whole system and throw in some headers non-emission. And you def need to make a rad support. you fans will start hitting the water pump causing it to break the housing. Or possibly rub a hole in the radiator hose
tomorrow will be radiator support day.
what sensor was in the elbow? trying to decide where to replace it and if its necessary. I dont need emmissions here, but new headers wont be till next year. I need a cat-back first anyway.
thanks for the informative post hillbilly
If your letting the radiator and condenser just lay there you are dumb and should never be allowed to own/drive a car again.
The sensor that went in the elbow is the idle air temp IAT sensor. You can either buy an extension on cut/slice and soldier the wires to desired length and place it where ever you want on the CAI. Alot of people move it as far away from the heated engine bay as possible to trick the engine into thinking it is receiving colder air by getting the reading at a further away location. But regardless it does need to be reinserted back into the CAI in some shape form or fashion. GL
I thought about using the fog light openings, but after some investigating, decided it would be more difficult, with little gain.
I was able to fit the rad. cover back on after some cutting.
I think this will help with airflow into the radiator more than anything, as the radiator was held down by the intake.
And no, I wont post anymore pics of my dirty, high mileage, oil leaking, stock motor.
