abs delete
Old Feb 6, 2012 | 10:41 AM
sweetbmxrider's Avatar
Originally Posted by FAD2BLK93
So this would be more of a track car only deletion with a trans brake?
A trans brake is not used to slow a car down if that's what you are thinking
Old Feb 6, 2012 | 11:06 AM
lt1slowz28's Avatar
http://www.sjmmanufacturing.com/cam_brk_lt1.html
al that is the one we are all talking about using... sponsors all all on the right side of the page, the 102921 billion little icons
Old Feb 6, 2012 | 11:08 AM
Big Al's Avatar
Yes, but how does one know what they supply? If I had to go to each one to see what they sell that would take a few lifetimes
Al 95 Z28
Old Feb 6, 2012 | 11:25 AM
RamAir95TA's Avatar
Al 95 Z28
A phone call goes a long way.
Old Feb 6, 2012 | 11:27 AM
lt1slowz28's Avatar
yea... uh... there is a sponsors sales section on the forums, I have used it from time to time to check for deals other than that I don't think they have a nice organized list of "what sponsor sells what".
Old Feb 6, 2012 | 08:41 PM
darrell hoagland's Avatar
i just installed mine this weekend,looks great just got to wire everything up now
Old Feb 7, 2012 | 12:07 AM
AChotrod's Avatar
Sjm kit on my ride
Old Mar 8, 2012 | 09:34 PM
ccd_1606's Avatar
I just ordered this kit, how hard are the factory lines to get to when it comes to flaring them?
Old Mar 8, 2012 | 09:41 PM
F0x Slaughter's Avatar
Flaring brake lines is simple.
02sleeperz28's Avatar
SJM kit here as well.
Old Mar 8, 2012 | 09:45 PM
ccd_1606's Avatar
ok do you actually flare the flexible line that goes to the abs module, or do you go lower and flare the hard lines?
Old Mar 8, 2012 | 09:47 PM
  #32
lt1slowz28's Avatar
I didn't have any flex line... cut and flared hard lines... but mine is the older style of the two.
Old Mar 8, 2012 | 09:51 PM
  #33
What are you talking about flex lines? The only flex lines in a braking system are where it attaches from the body to the calipers. Thats because the calipers travel up and down with the suspension.
Master cylinders (every single one I've seen) are hard lined down to the portioning block. Then to both sides, then flex lines. From block to rear then flex lines to both sides.
Old Mar 9, 2012 | 07:03 AM
  #34
ccd_1606's Avatar
oh for some reason i thought there were flexible lines running into the abs block, ill have to take a look under my hood today.
Old Mar 9, 2012 | 08:11 AM
  #35
keithcampbell's Avatar
okay stupid ? because someone asked if i was going to do this but why do you take off the abs
Old Mar 9, 2012 | 10:19 AM
  #36
There are braided lines in some of the systems actually. I believe its between the master and abs module but its been awhile since I have encountered one.
Old Mar 9, 2012 | 12:39 PM
  #37
93M6Formula's Avatar
A few reasons....
1. It just takes up space under the hood and removing it makes it look cleaner.
2. Half the time it doesn't work and on a weekend cruiser there really is no need for it in my opinion.
3. Weight savings, it"s not a whole lot but it's worth something.
I will be doing this A.S.A.P. cause mine doesn't even work and i'm in the process of cleaning up my engine bay of clutter.
Old Mar 9, 2012 | 01:59 PM
  #38
Originally Posted by 93M6Formula
A few reasons....
got it thanks from what i heard if u take the abs and a/c out and then put the batt in the back it should be a 50/50 for weight is this true
Old Mar 9, 2012 | 04:24 PM
  #39
94LT1TA6spd's Avatar
This is good info. I too have been looking at various kits, and am leaning towards SJM kit.
I am glad to see some positive reviews here.
Old Mar 9, 2012 | 05:59 PM
  #40
ccd_1606's Avatar
On my car there are some flexible lines, all four of the actual brake lines are flexible then turn into hard lines then screw to the abs block.
