Injectors?
Old Feb 6, 2012 | 12:21 PM
Luke1996ta's Avatar
Default Injectors?
Thinking about upgrading to bigger injectors how big should I go or will I get more hp with doing something else
My car
M6,ai cam 230/238 566/566, lt headers, 411 gears, 125 shot
Thanks for the help
Old Feb 6, 2012 | 12:32 PM
Rob94hawk's Avatar
From what I've been told through a reputable nitrous sponsor here 42# injectors are the way to go. (Nitro Dave's Nitrous Outlet)
Stock bottom right?
05HD's Avatar
Bigger injectors don't add more power.
All you need is injectors big enough to add a sufficient quantity of fuel to the air your engine has ingested to provide a suitable air to fuel ratio. Getting more air in makes more power, unless you can't add enough fuel to get to the "best power" air to fuel ratio (somewhere close to 13:1 on n/a and nitrous engines).
Old Feb 6, 2012 | 12:33 PM
stuart4185's Avatar
something you should really discuss with your tuner. what size do you currently have? is the car running out of fuel on top end? is the car tuned for the current setup? what are you planning on doing in the future?
Old Feb 6, 2012 | 12:48 PM
Luke1996ta's Avatar
I haven't dyno my car yet just wanting to just the most out of what I have before I dyno it And I just have stock injectors now
Old Feb 6, 2012 | 01:03 PM
TravisMcGill2000's Avatar
If your using a wet kit then stick with the stockers.
Old Feb 6, 2012 | 01:09 PM
bowtienut's Avatar
Like Stuart said, talk to your tuner.
Where are you getting it tuned? I see you're not too far from Dayton. There's a good LT1 tuner/dyno near there in Beavercreek.
Unless you're planning on a dry kit, SVO 30# injectors are all you will ever need, but...........your tuner needs to agree to that. Unfortunately not all of them subscribe to the same theories.
Old Feb 6, 2012 | 02:44 PM
Luke1996ta's Avatar
Wet shot an cincy speed is where I'm going
Bowtienut u know there rates ?
