Idler pulley - A/C delete
Old Mar 20, 2004 | 08:29 PM
bowtie9696's Avatar
Default Idler pulley - A/C delete
Anybody know where I can get an A/C delete idler pulley (besides a dealer). I know these cars exist, but I haven't even been able to find the belt. I'm sure it's on this site somewhere, but I haven't been able to find it. Thanks.
Old Mar 21, 2004 | 10:59 AM
Scott96LT1's Avatar
I got mine from GM parts direct. It took about 2 weeks because they special order it. The 1LE A/C delete pulley is GM p/n 10115875.
Old Mar 21, 2004 | 11:25 AM
oOoLy's Avatar
Any pics plz ???
Old Mar 21, 2004 | 12:15 PM
Scott96LT1's Avatar
http://www.cardomain.com/memberpage/525892/5
Pic is at the bottom with part number.
Old Mar 21, 2004 | 12:35 PM
bowtie9696's Avatar
Thanks Scott, I guess that price isn't too bad. Does it require a different belt, if so did you get your belt from them as well, or have you found another source?
Old Mar 21, 2004 | 09:20 PM
Scott96LT1's Avatar
No problem . As for the belt, the answer is maybe. I'm putting my 1LE pulley on this weekend when I get time and I'm going to find out if I need a different belt then. Some people get by on the same belt, others need a slightly shorter one. So right now I have the same Dayco belt that I've been using with my March UD & OD pullies.
Old Mar 21, 2004 | 11:37 PM
00Z-28-LT1's Avatar
how much do they cost from GM?
Old Mar 22, 2004 | 07:07 AM
bowtie9696's Avatar
It listed for about $34 from gmpartsdirect.com
Old Mar 23, 2004 | 12:48 AM
Parker TX's Avatar
i got mine from the dealership in dallas, they had it in stock for about $28. also there are a couple of them on ebay, and you should be able to run the stock belt.
Old Mar 23, 2004 | 10:30 AM
1point3liter's Avatar
Why is this part needed?
I'm running with out a/c or power steering.
Old Mar 23, 2004 | 10:31 AM
oh shiz.. just realized I'm in the LT1 area.
Old Mar 24, 2004 | 06:10 PM
BizZzatch350's Avatar
Moderator
Only people that have belt problems are the people with after market pulley, the 1le is meant to keep the belt routing the same and use the same size belt.
