prob. one of the most asked questions
Old Feb 20, 2012 | 11:19 AM
POPZ's Avatar
Default prob. one of the most asked questions
i bought a 95z28 roller then i bought a 96lt1 with 6 speed tranny with 22kmiles. the car had nothing under hood. it took 4 months and 2 weeks for a guy to install. well, it runs like crap. i have drove it less than .4mile. i put a new maf on it and it thought it helped . maybe just idled better for a few minutes. it skips,backfires , and doesnt have any power. i have figured out the best thing to do is have a REAL MECHANIC check it out. a friend of mine works at gm dealership and is bringing his scanner to check it just as soon as he has time. after all the reading i have done...sounds like optispark. if it is, i have found some cheap ones on ebay. what is the difference in 150$ vs. 450$. im having m.r.i. on my back thursday and dr. is saying prob surgery. i cant afford anything expensive as it is. what is a good price for opti and having it installed? if motor really has 22k miles should'nt waterpump and wires still be good as new? somebody tell me something good...im tired of bad news. is lt1 really worth it?. it is a really sharp car. inside and out.
Old Feb 20, 2012 | 12:36 PM
sreve's Avatar
Quote: the car had nothing under hood
The OBD2 knock sensors '96 are not compatible with a OBD1 pcm '95 ,they look alike.
It's real easy to put the plug wires on backassward on a LT1 car.
Old Feb 20, 2012 | 02:12 PM
jaycenk's Avatar
What PCM and harness are you using?
Old Feb 20, 2012 | 03:23 PM
POPZ's Avatar
Default i dont know what he obd he used
the motor i bought had a wiring harness..the guy that put the motor in supplied everything else. he had several camaros that he was using for parts cars.would 95 and 96 motor not be the same? how can i tell just by looking?
Old Feb 20, 2012 | 04:25 PM
69gto96z's Avatar
The engine is compatible, however, a 95 is an OBDI car, a 96 is an OBDII. Not all of the sensors are the same as stated above.
Old Feb 20, 2012 | 07:30 PM
stuart4185's Avatar
so you dont know what he put in? the 96 engine/harness can only be used with a 96 or 97 PCM. there are OBD2 to OBD1 conversions out there, but you need to find out exactly what parts he put in. im sure theres a part number on the PCm its self somewhere, i dont know where tho
Old Feb 20, 2012 | 08:33 PM
POPZ's Avatar
Default ready for a red solo cup
i talked to a mechanic today. he is going to try to check it this week. he said that it seems like the guy that put the motor in ,screwed up some wiring. the mechanic is like most of you guys... talks way over my head. he works at a gm dealership. do most of you guys work at nasa? i just want it to run like it should, lesson learned. if you dont know what you are doing, buy something already running.
Old Feb 20, 2012 | 08:48 PM
stuart4185's Avatar
NASA lol nope just a lot of time reading technical forums aka shoebox's website tuner cats website, and getting taken for a ride once by a shitty mechanic that pissed me off. another word of advie buy the haynes manual and keep it in the crapper, youll remember more than you think and it explains things with pictures fairly well
Old Feb 21, 2012 | 01:46 PM
jaycenk's Avatar
All he needs to do is pull the PCM out and check the ID tag on it and find out if it's obd1 or obd 2 then he needs to check the knock sensor and see if it is an OBD 1 or OBD2. You have to have the correct knock sensor for what ever PCM you are running.
You can look at the wire harness that goes down to the starter and see if it had a wire that goes forward to the front of the timing cover to a pickup. If it has this it is an OD2 harness. If not It is OBD1. The PCM has a set of numbers on a sticker tag. those numbers can tell you what PCM is in it.
Old Feb 21, 2012 | 05:39 PM
sreve's Avatar
Here's some numbers
16188309 Knock module - LT1 95 Impala SS
16217700 Knock module - LT1 F-Body OBD-I
16214661 Knock module - LT1 F-body OBD-II
16214671 Knock module - LT1 Corvette
16214681 Knock module - LT4 Corvette
16214691 Knock module - LT1 Impala 2
'95 LT1 PCmS
GM $225
Ident: 16188051
Ident: BDTF
Ident: BHZU
Ident: BJHJ
Ident: BJHK
Ident: BJHL
Ident: BJHM
Ident: BJHN
Ident: BJHP
Ident: BJHR
Ident: BJHS
Ident: BKN
CAMARO 94-95 Elec Cont Module (ECM); 8-350 (5.7L)
CAPRICE 94-95 Elec Cont Module (ECM)
FIREBIRD 94-95 Elec Cont Module (ECM); 8-350 (5.7L)
FLEETWOOD 94-95 Elec Cont Module (ECM); (8-350, 5.7L)
IMPALA 94-95 Elec Cont Module (ECM)
ROADMASTER 94-95 Elec Cont Module (ECM); (8-350, 5.7L)
'96 PCMS
Controller (PCM)
GM $225
Ident: 16214399
Ident: BSDJ
Ident: BSDK
Ident: BSDL
Ident: BSDM
Ident: BSDN
Ident: BSDR
Ident: BSDS
Ident: BSDT
Ident: BSDU
Ident: BSDW
Ident: BSDX
Ident: BSDY
Ident: BSJJ
Ident: BSJK
CAMARO 96 Elec Cont Module (ECM); 8-350 (5.7L)
CAPRICE 96 Elec Cont Module (ECM)
CORVETTE 96 Elec Cont Module (ECM); (8-350, 5.7L)
FIREBIRD 96 Elec Cont Module (ECM); 8-350 (5.7L)
FLEETWOOD 96 Elec Cont Module (ECM); (8-350, 5.7L)
IMPALA 96 Elec Cont Module (ECM)
LESABRE 96 Elec Cont Module (ECM); 8-350 (5.7L)
'97 PCMS
Controller (PCM)
GM $225
Ident: 16242921
CAMARO 97 Elec Cont Module (ECM); 8-350 (5.7L)
FIREBIRD 97 Elec Cont Module (ECM); 8-350 (5.7L)
Old Feb 21, 2012 | 05:51 PM
sreve's Avatar
Although the mismatch on knock parts will screw with timing but not to the point of back fire. plug wires on bank two is a good to start
Old Feb 21, 2012 | 07:32 PM
POPZ's Avatar
Default thank you guys
i am saving all the info. for my mechanic to look over. he is a good mechanic but its always good to have folks like you guys to remind him of this info. it really is amazing to read all the post from you guys. my last hotrod was a 1969 dodge dart gts. with a 340.i kept it for almost 15 years.i knew the old stuff on how to make the car go fast but.it was nothing like todays cars.i have always like muscle cars and fast cars of anykind . i am 55 now and way behind. i have always gone to dragstrips and talked to great mechanics. i have been to orlando to the world nats 5 times. until i found ls1 tech.i didnt know there was so much info on the internet. thanks guys
Old Feb 22, 2012 | 08:04 AM
jaycenk's Avatar
got start with the basics and work the problems. After you figure out what is in it then you can move on to trouble shooting and hopefully its something simple. Good luck with it.
Old Feb 22, 2012 | 01:03 PM
jesvilla's Avatar
Yeah, make sure you have the correct matching PCM, sensors and wiring harness.
Here's what happened to me, I bought a '97 Z/28-LT4 conversion, somebody changed the PCM for an OBD1 ECU, 7-8 codes were coming up and car ran terrible, I found a '97 PCM, hooked it up and only 2 codes came up, I've found a few other problems like vacuum leaks due to wrong intake gasket, wires touching exhaust pipes and loose nuts and bolts everywhere, but car runs good now and no codes are coming up anymore.
Good luck, just be patient and get people that know these cars working on it.
