Can I use EFI connection Timing cover and use 1x Cam signal for my GEN 7 DFI ???
Need some help from anyone who can understand the specifics better than I can. I figured why not just ask out loud and maybe someone can chime in.
Right now I am running the gen 7 dfi and using a dual sync distributor. As you know the dual sync requires a cam and crank signal and this comes from the dual sync distributor right now. For accuracy I am trying to get a better and more reliable signal for both cam and crank and be able to use a regular small cap Dizzy without the unreliable electronics inside it.
For Crank, I have on order an ATI magnetic shell that will go on my damper. I will use an msd pickup and have that sorted as the dfi will read the signal.
For Cam, I am thinking/want to run the efi connection billet timing cover and their cam sensor which from what i remember (havnt looked in a few months so forgive me if I forget) is a 1x on the end of the cam.
my question is can I get this setup to provide a 1x signal to my gen 7 dfi?
Furthermore if it IS possible... then i think i can just shave off teeth on the efi crank wheel down to 4 and give my dfi a crank as well??
with a cam pickup right on the cam and a crank off the damper I would feel comfortable knowing they are accurate.
any thoughts are appreciated.
Thats something I never even considered.. That the cam didn't need to be as accurate as the crank. It makes sense now wow .. After all it is just a 1x .
Now I could just run the accel dual sync for cam pickup and have the capability to use crank is the mad fails for any reason. I guess I could just keep a spare dual sync in the car.
The biggest reason for wanting the cam pickup from the efi connection setup was reliability. I just figure keeping any electronics out of the distributor would be better.
I guess I would have to figure out what type of a signal the gm ls sensor will send out and if/how to convert it to what the DFI requires. Problem is I'm clueless about electronics when it comes to signal types etc
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
http://www.summitracing.com/parts/MSD-2346/
We run a classic fast box. I put the magnet on probably 5 years ago. It hasn't moved yet. If you wanted you could counter sink it into the gear. But I don't think its necessary.
That sounds fantastic I may try this. Thank you!! Do you have any pics of the setup? I'm guessing it fits fine behind the water pump housing? What are you using for crank? I considered an msd flying magnet but there's barely any room in a y body at the front of the motor so I went with the ati shell. I had a 96 cover and sensor that uses a 4 tooth reluctor but again I'm clueless as to what type of signal it priloduces and if/how I could make it compatible with the gen 7
