Crank Trigger Wires and BS3 on a Lt1
Old Feb 24, 2012 | 02:43 PM
Formula Stocker's Avatar
Default Crank Trigger Wires and BS3 on a Lt1
I am trying to finalize the wiring on my LT1 Stock Eliminator Project with a BS3. I installed a crank trigger and currently have the wires running to my MSD iginition box. I know this isnt right so my question is.....what wires on the BS3 main harness do i connect to the green and purple crank trigger wires?
Thanks for your help
Old Feb 24, 2012 | 03:53 PM
Tony Shepherd's Avatar
Did your BS3 come with a wiring diagram or PCM pin-out diagram?
Old Feb 24, 2012 | 04:04 PM
Wicked94Z's Avatar
should use crank +/- inputs for the crank trigger wires, then your EST/Points output to trigger the ignition box. This is for DFI but should be similar for BS3
Old Feb 24, 2012 | 04:54 PM
it did come with a diagram for the opti spark but it incorporates a stock GM ignition module. Since this is no longer being used, I have to deviate from the schematic a little.
Thanks for the help wicked. Ill take a look at that tonight
Old Feb 24, 2012 | 08:31 PM
Got it figured out. Thx
Old Feb 25, 2012 | 07:20 AM
joelster's Avatar
Any pics of the car? What class will you be in? There are a few stock eliminator guys in here.
Old Feb 25, 2012 | 07:34 PM
Prob gonna run c/sa. Think I'm eligible to run b,c,and d. There is a bunch of pictures If u search "formula stock eliminator" build on here
