comp cam rocker question
Old Feb 26, 2012 | 07:20 PM
lt1_t56's Avatar
Default comp cam rocker question
#CCA-17005-16 will i have a clearance problem with the stock valve covers?
I'm going with 7/16 stud bolts
Old Feb 27, 2012 | 08:08 AM
SS RRR's Avatar
Village Troll
Depends if the adjusting nuts are tall or normal sized. You will most likely have to modify the cross braces on the inside of the stock valve covers for them to properly clear. If the adjusting nuts are tall, it will work, but will make contact with the tops of the valve covers and may contribute to false knock if you are still running a knock sensor.
