Speedometer accuracy
Old Feb 27, 2012 | 08:30 AM
wrd1972's Avatar
Default Speedometer accuracy
First off the MPH on my Scanmaster and my GPS are perfectly in sync, no issue at all there. Its the needle that starts to read a little low at higher speeds, usually over 60MPH.
At 30MPH on the Scanmaster, the needle shows 30 and the same thing at 55. Once you hit 60 and higher, the needle starts to fall a little behind. So at 75MPH on the Scanmaster, the needle reads 72MPH.
Is there a parameter in the tune that can keep the needle more in sync with the MPH reading in the PCM?
Old Feb 27, 2012 | 10:23 AM
jester1614's Avatar
I believe its a computerized mechanical reading from the VSS (vehicle speed sensor) in the tailshaft of the tranny (if a4 not sure of location on m6)
As far as i know there isnt any way to recalibrate it
Old Feb 29, 2012 | 07:57 PM
AChotrod's Avatar
Mines way off with the th350 swap reminds me I need to get that tuned!
Old Feb 29, 2012 | 08:25 PM
pancho toco loco's Avatar
You could try replacing that sensor
Old Mar 2, 2012 | 01:54 PM
jester1614's Avatar
one thing that might be able to be done, is alter the tire size in the tune to try and calibrate it.
Old Mar 4, 2012 | 08:05 PM
nascarnate326's Avatar
Odd. Mine is dead on until 90+.
Diff wheels?
