Exhaust Leak
Old Mar 3, 2012 | 09:11 AM
JDub3's Avatar
Default Exhaust Leak
Ok, I need help. I put some pacesetter headers on a couple years ago. I blew the header gasket, so I bought new ones off of summit and replaced them. Now I still have an exhaust leak on the driver side at each d port. Could it be that I just bought a bad gasket or would there be something worse like a warped head? If it is a gasket issue does anyone have a suggestion for a good set of gaskets? Thanks for any help.
Old Mar 3, 2012 | 10:09 AM
96LT1355Z28's Avatar
Fel-Pro 1406 is what I've used for 2 years with Pacesetter headers, no leaks. They're available at any national chain parts store.
Old Mar 3, 2012 | 04:03 PM
Spartan7's Avatar
Either the header flange is warped, or you're not tightening them enough. I also prefer Fel-Pro.
Old Mar 4, 2012 | 09:27 AM
SS RRR's Avatar
Village Troll
What kind of gaskets?
Old Mar 4, 2012 | 10:25 AM
stuart4185's Avatar
i use the felpros too, anyone use the aluminium gaskets that are out there?
Old Mar 4, 2012 | 10:42 AM
SS RRR's Avatar
Village Troll
Not unless you know surfaces are near perfect. Using a steel core gasket is far better when dealing with aftermarket headers where the flange may not be anywhere near as level than what stock exhaust manifold is.
Old Mar 4, 2012 | 03:28 PM
JDub3's Avatar
I think mine were the aluminum core. I will try the felpros. Otherwise I'm guessing something is warped. Thanks for your help guys.
Old Apr 3, 2012 | 02:44 PM
lt1needingboost's Avatar
felpros me 2
Old Apr 10, 2012 | 10:26 AM
ahritchie's Avatar
I had the exact same issue with pacesetter mid-tubes....both copper and felpro gaskets leaked on the passenger side....of course the side which is hardest to get to The header flange was flat when we put a straight edge on it got some Earl's "pressure master" graphite foil gaskets and problem solved! My mechanic mentioned they are the nicest header gaskets he's ever seen lol.
http://www.summitracing.com/parts/EAR-29DA3BERL/
