Lights flickr @ idle
Old Mar 4, 2012 | 04:27 AM
Mohammed's Avatar
Default Lights flickr @ idle
Interior, headlights and rear lights flickering..
What to check ??? and how
Old Mar 4, 2012 | 05:23 AM
Rob94hawk's Avatar
All your connections to the battery terminals and alternator nice and tight? Might be a loose ground somewhere.
Old Mar 4, 2012 | 01:05 PM
stuart4185's Avatar
flickering or diminished brightness? does it have underdrive pulleys? drive it more than once a month? alternator might be losing its battle, id start there
Old Mar 4, 2012 | 01:11 PM
SS RRR's Avatar
Village Troll
Yep. Get a volt meter and prod the alternator. Should be a steady 14.5 volts.
Old Mar 4, 2012 | 01:37 PM
pancho toco loco's Avatar
+1 on the alternator
Old Mar 4, 2012 | 02:17 PM
shbox's Avatar
Any added on equipment that adds electrical load?
Idle speed at stock specs?
Old Mar 4, 2012 | 02:32 PM
Mohammed's Avatar
flickering , stock pulley. weekend drive only
I have a voltmeter , do I check the voltage on the battery terminals while the car is running ??
No , it has boltons and cam only. + electric water pump.
Idle speed about 800rpm.
Old Mar 4, 2012 | 02:38 PM
stuart4185's Avatar
take a volt measurement before and after. if the after measurement is higher, the alt is working, if the after is lower, like 11.8 its the alt.
Old Mar 4, 2012 | 03:43 PM
shbox's Avatar
Measure on the battery terminals while running. Report values.
EWP= extra load.
If this is something that just started happening, it's probably a loose cable or alternator problem.
Old Mar 4, 2012 | 03:59 PM
Mohammed's Avatar
Thanks I'll check that tomorrow.
EWP= extra load.
it just started, I hope I find out the problem soon.
Old Mar 4, 2012 | 04:16 PM
SS RRR's Avatar
Village Troll
Yes. Check directly off the terminal on the alternator while engine is idling and it should read steady. If it fluctuates then more than likely the alt. is going bad. Check battery as well with engine running.
Old Mar 5, 2012 | 02:56 AM
Mohammed's Avatar
UPDATE :::
Checked the alt , engine off : 12.5 , engine running : 14.8- 15.0
I didn't find lose wire and I don't know the location of the ground wires .
I found the left knock sensor wire was cut !!! How to remove the sensor to fix the wire ??
is there any info where I can find all the grounds on the car to check them one by one ??
Old Mar 5, 2012 | 05:57 AM
SS RRR's Avatar
Village Troll
Shoebox's site should have schematics- www.shbox.com
Did you check the battery with the engine running?
I don't believe you need to remove the sensor to fix the wire. Is the connector to the sensor still there? If so, solder the wire back together with a piece of shrink wrap. If the sensor is gone hopefully you can find a company to ship one to you if there isn't a place available to you locally.
http://www.eficonnection.com/eficonn...ngineType.aspx
Old Mar 5, 2012 | 06:34 AM
shbox's Avatar
IDK, that running voltage sounds a little on the high side. The voltage regulator in the alternator might be causing fluctuation of the voltage and hence the flickering. I'd put my money on that as the cause.
BTW, he has a Corvette. Not all schematics on my site are going to apply.
Old Mar 5, 2012 | 09:18 AM
SS RRR's Avatar
Village Troll
Blast! Shbox'd agaaaaiinnn!
Old Mar 5, 2012 | 10:24 AM
Mohammed's Avatar
Yes , checked it with engine running and got 15.0 .
The connector still there I didn't figure out how to remove it, but I need to because the wire is cut from the sensor itself. I believe I can find it locally.
Do you suggest removing the alt and let someone check it ? or get another alt and try if that works !!
Hey , your website got a lot of good info. I used it before . Thanks
Old Mar 5, 2012 | 04:15 PM
shbox's Avatar
Having the alt tested off the car might be a good idea, if there is some place to have it done. Some auto electrical shops might be able to evaluate it while still on the car. I don't recommend you replace it until you have some reasonable proof it is the trouble. Internet diagnosing is not an exact science.
