I might be having opti problems again..
I have a msd distributor with msd coil and msd 6al with a 2 step and msd plug wires. this set up has been on the car for a few years. and its been run off the stock ecu, megasquirt is fuel only.
I check spark from coil and no spark so I got a brand new msd 6al because i thought it was part of the problem. I install it and I got spark at the coil now. so I try to turn it on and nothing...
I check to see if im getting spark to the plug and it pulses but with a big pause in between sparks. like: spark....crank crank....spark
so I check the ecu and it checked out fine, I check for codes and it only gives me 12 and 12 means its working.
so I think that the rotor might have bursted inside or somthing like that because this is strange to me. oh and btw motor only has like 3 miles on it... that includes cap and rotor.
any thought on what could be happening?
I just now replaced the distributor and still nothing...
http://shbox.com/1/4th_gen_tech2.html#opti_test
so now I cant finaly put it all back together and start some tuning. hopefully no more problems.
here is a quick video http://www.youtube.com/watch?v=xlQ-KwTCcfY
