Can I get rid of this?
Old Feb 29, 2012 | 07:32 PM
fuzzyjk's Avatar
Default Can I get rid of this?
Can anyone tell me if I need the hose that goes from the passanger side valve cover breather to the passanger side of the throttle body? I am trying to get rid of unnessasary clutter under the hood. Can I just put a cap on the throttle body where the hose is meant to go and put in an aftermartket breather on the valve cover? Thx
Old Feb 29, 2012 | 07:51 PM
AChotrod's Avatar
I capped the TB and use a breather on the VC. Its debatable if its good or not to do.
Old Feb 29, 2012 | 08:04 PM
notsue's Avatar
Two votes for it being okay from my garage. I'm sure someone will chime in on why you shouldnt tho...
Old Feb 29, 2012 | 08:08 PM
guppymech's Avatar
The hose from the throttle body to the valve cover is part of the pcv system and that air is accounted for with the MAF. When not using this complete system you are introducing unmetered air into the combustion chamber however minute it may be.
Old Feb 29, 2012 | 08:17 PM
RamAir95TA's Avatar
guppymech is right. However there hasn't been much proof either way. Having said that I've deleted mine long ago.
Old Feb 29, 2012 | 10:08 PM
shbox's Avatar
Aside from the unmetered air introduced, I don't see how putting a breather on really cleans up anything. You remove a hose, but add a breather. It lets smelly crankcase fumes out and possibly causes oil residue on the valve cover. My vote is to leave the hose on and let the PCV system work as intended.
Old Feb 29, 2012 | 10:13 PM
F0x Slaughter's Avatar
My question is how is it being metered by the MAF? If its venting pressure from the crankcase then going directly into the throttle body that means its no where near the MAF let alone re-entering the system in front to flow through the MAF?
Old Feb 29, 2012 | 11:34 PM
AChotrod's Avatar
It plugs the hole in the VC
Old Feb 29, 2012 | 11:50 PM
guppymech's Avatar
You're not understanding the LT1 pcv sytem correctly. Air from the air filter that has passed through the MAF comes out the side of the throttle body goes into the passenger side valve cover though the engine and out the pcv valve on the drivers side of the intake manifold (passage way connected to lifter valley) from there it goes back into the inside of the intake and is mixed with the rest of the air from the throttle body and burned.
Old Mar 1, 2012 | 12:10 AM
gregrob's Avatar
A performance engine has no business sucking oil into the intake.
Run a catch can system.
Old Mar 1, 2012 | 06:42 AM
shbox's Avatar
Yep, it is important to know how things work. The PVC air is like the rest of the air that passes through the air filter. It just takes a longer way around. If you have no MAF (like a 93), then that part of the equation is negated.
Old Mar 1, 2012 | 07:08 AM
fuzzyjk's Avatar
Thx much everyone, since I am going SD, it's going to be removed. Shbox & Guppy, you really explained it well. Thx.
Old Mar 1, 2012 | 08:58 AM
93M6Formula's Avatar
Good thread, i've been wondering the same thing, and since I have a 93, it's going to be removed then since my hose is cracked anyway.
Old Mar 1, 2012 | 09:06 AM
whytryz28's Avatar
I am SD and I still have it. Just sayin...
Old Mar 1, 2012 | 09:32 AM
wrd1972's Avatar
Aside from the emmisions benefits, the PCV system helps to remove moisture from inside the motor than can possibly lead to quicker breakdown of engine oil and to a lesser degree, corrosion on metallic surfaces such as the top of non aluminum rockers. As the engine heats up and cools down and also depending on weather conditions, you will certainly build up this moisture inside the motor and there is no way to avoid it. BTW, that white creamy stuff under the oil filler cap, its moisture.
In the old days before the PCV systems, the motors had road draft tubes which were long 1" metal tubes connected to the back of the intake and they hung down about 18" behind the motor. The moving car would create a vacuum draw on the road draft tube and ventilate the inside of the motor and help remove moisture from inside the motor.
Removing the PCV IMO has no performance benefits period and can only negatively impact things such as long term reliability of you motor so whats the point?
The biggest negative impact with our PCV and most other PCV systems, is the introduction of oil back into the engines pie hole as a result of upgrades and revving to higher RPMs. I fought this problem for a while and it was bad enough that if you looked into my intake plenum, it was totally coated with oil and from time to time, you could smell oil burning out the exhaust when enough built up and it dripped into a runner.
The solution to this problem as already stated, is to install a PCV oil catch can in the hose between the PCV valve and the front of the intak, just below the throttle body. To this day, I no longer have any oil contamination in the plenum of my intake plus I have a much cleaner running motor.
Lastly if the PCV is deleted, there is no system in place to remove the normaly genertated moisture from your motor as inteded by the manufacturer and I cant see how that can be a good thing.
Old Mar 1, 2012 | 09:54 AM
pillarpod's Avatar
what kind of catch can are you running?
Old Mar 1, 2012 | 10:21 AM
wrd1972's Avatar
Its made by Norris Motorsports and cost around $100 from WS6store.com and is worth every penny. It is a very high quality machined aluminum body with a removable top plus it has a drain valve on the bottom. It comes with a mount that can attach nearly anywhere and I have mine mounted on the front of the driver side head.
After about a thousand miles of driving, there might be around 1/4" to 1/2" of oil collected in the bottom so in reality, I would only have to empty it every 10K miles or so.
Old Mar 1, 2012 | 11:24 AM
Rob94hawk's Avatar
Where's that hose going to and is it open to air or sealed off?
Old Mar 1, 2012 | 11:29 AM
wrd1972's Avatar
In stock form, there is a metal tube from the PCV valve to the front of the intake. I removed the metal tube, replaced it with a rubber hose and the catch can installs right in the middle of that hose. Very easy install.
Old Mar 5, 2012 | 06:27 PM
Driftunit's Avatar
um this could be wrong but i was always told that tube was to release the oil vapors in the vc.. therefore your intake would be pulling it out with the vacuum it makes. when you remove that hose you are preventing oily fumes from goin into the intake.. the breather in its place would act as a vent not and induction site... which explains also why you may see some higher hp cars that have a line going from each vc to a lower point on the header so the vacuum made by the exhaust can replace that suction
ive heard of and seen this used in several different occasions, but feel free to correct me if im off
