CNC Head Surprise
Old Mar 9, 2012 | 11:46 PM
fisherz28's Avatar
Originally Posted by F0x Slaughter
Does the last 3 of the casting say 634? Cause AI only CNC 634 and 374 heads.
Last three are 648. So new plan is pull the motor and freshen it up with some new bearings, higher comp pistons, have the heads gone thru and toss in a new cam. Sound like a good direction?
Question: The cars oil pressure drops after driving on the freeway for any period of time. It's fine when I'm actually cruising but once I hop off the freeway and come to a stop it will drop for about a second to 0 then hops right back up. My guess is either the bearings are toast or its a high volume pump with the stock pan.
Old Mar 10, 2012 | 09:01 AM
SS RRR's Avatar
Village Troll
Originally Posted by fisherz28
From the little I've found on the Lingenfelter heads they are stamped LPE this have a casting number on it but I don't know if they mean anything. There is something VERY faint on the drivers head: JL011398C
Dunno. Maybe they started doing that later? I bought mine from LPE 15 years ago and they aren't stamped. The one thing that makes me think it is not from a LPE CNC program is the CNC steps stop around the bowl area.
Old Mar 10, 2012 | 10:14 AM
jaycenk's Avatar
These are Mahle -16cc pistons
Old Mar 10, 2012 | 11:20 AM
fisherz28's Avatar
I have no clue I've only been around these cars for a few years so im still pretty green about em and there history. I can get some better pics with them cleaned up a lil better.
Nope, they are stamped SRP on the underside ive got a pic on my camera at home I'll throw up later. Pistons look pretty different too. Check out the bottom of the dish there is a step on min that isn't completely round as well as a small widows peak right by what i would consider the valve relief portion of the pistons.
Any ideas on what would be the best route to go here im thinking just pull the motor, new pistons and freshen it up....
Thanks for all the responses guys
Old Mar 10, 2012 | 11:58 AM
jaycenk's Avatar
yes I know they are not Mahles I meant that I posted it up as a comparable for ya.
Old Mar 10, 2012 | 02:02 PM
fisherz28's Avatar
Did i mention I'm partially retarded?
Old Mar 10, 2012 | 02:10 PM
jaycenk's Avatar
We all are lol. By the way I would throw a mechanical oil pressure gauge on it and verify that the cluster gauge is reading correct but it looks undriveable right now?
Old Mar 10, 2012 | 06:49 PM
fisherz28's Avatar
Yup, at the moment its undriveable. I replaced the sensor when I snapped the old one but never tossed a mechanical gauge on it. It's been like that since I bought it tho the oil pressure is normally fine but will drop after coming to a stop if I've been driving for a while or go WOT then stop shortly there after. If i were to pop a few main caps off should I visibly be able to see whether the bearings are fine enough?
Old Mar 10, 2012 | 10:37 PM
1961ba427's Avatar
Originally Posted by 96capricemgr
I kind of doubt Lingenfelter would use SRP. Then again it has a Callie crank..........
There was also a company out of FL that did some mediocre CNC LT1 heads. Friend had them and his heads/cam car ran cam only numbers.
1. I think 96capricemgr is referring to CNC Cylinder Heads (Out of business for awhile now). I have those and they do not look like the ones you have pictured. I won't make any guesses as to whether they are better or worse in flow numbers, port design, etc. I just know they are different.
2. As far as the CNC heads/cam car running cam only numbers: There is an unmeasureable difference between one car and it's results and another beyond just cylinder heads. I'd be willing to bet there are MANY heads/cam cars that don't run the numbers that some of the best bolt-on only cars have ran...much less cam only. That is any brand heads/cam cars. Lots of them are 12 second only rides. I have ran better numbers with a 433 bbc with unported cast iron heads (in a bolt on suspension 61 Bel Air than alot of people with aftermarket aluminum headed 496's and 540's in Chevelles, Novas, and Camaros. Combination is everything.
3. I have CNC heads because that is what I got a great deal on and was willing to give a try. I'd have been just as quick to buy a pair of AI 200cc or LE2's....with no real preference between the two. I personally don't care what everyone's arguements are they are both proven performers in my opinion.
4. I have NO hp numbers or time slips (yet) for my CNC headed LT1 to support whether they work well or not, so don't think I'm claiming they are the best. If it's performance is subpar....I can always let everyone blame that on the off the shelf cc503 cam. LOL
Old Mar 10, 2012 | 10:46 PM
1961ba427's Avatar
OP, before you go buy new pistons I would weigh the cost versus the gain. Yes you will make more power with an optimized compression ratio, but you are talking about the cost of new pistons, rings, and a balance job. I don't have a guess without research what your current compression is, but if you could gain 2 full points and make a whole 4% increase per point that would mean what....maybe 40 HP at best. Not a small amount for sure, but perhaps you could get a portion of that with a slight mill of the heads and a thinner head gasket?
I'm not trying to say it isn't worth it....just throwing out something for you to think about. If it were my car and I just wanted a fun driver, I wouldn't swap the pistons. If I were building it to kick butt, I wouldn't think twice about shooting for around 11.5:1.
Old Mar 11, 2012 | 08:09 AM
bowtienut's Avatar
Originally Posted by 1961ba427
..2. As far as the CNC heads/cam car running cam only numbers: There is an unmeasureable difference between one car and it's results and another beyond just cylinder heads. I'd be willing to bet there are MANY heads/cam cars that don't run the numbers that some of the best bolt-on only cars have ran...much less cam only. That is any brand heads/cam cars. Lots of them are 12 second only rides. I have ran better numbers with a 433 bbc with unported cast iron heads (in a bolt on suspension 61 Bel Air than alot of people with aftermarket aluminum headed 496's and 540's in Chevelles, Novas, and Camaros. Combination is everything....
So true.
It sounds like you have the heads ported by Pete - CNC Heads, Pinellas Park, FL. In the late 90's/early 2000's, those heads were on some of the fastest B-bodies. Was it the heads, or just the owner doing everything else right? Who knows... All I can tell you is that they won't hold you back.
Old Mar 11, 2012 | 08:26 AM
  #32
1961ba427's Avatar
Originally Posted by bowtienut
So true.
Those are the ones. I have heard they have an extremely good intake port and a weak exhaust port (in comparison). The numbers I received with mine were great on the exhaust side. I don't know if they were with a pipe attached or not so that could effect it.
I hope you don't think I am trying to thread hi-jack you OP. I just wanted to let you know that your heads don't look like my "CNC Heads" branded ones, and to also let you know that just because they may not be one of the most popular brands going doesn't mean they won't be good. I've said it before and I will again....not alot of companies go through the trouble of offering a porting program for LT1's so I doubt they would do so on a port design that sucked.
Old Mar 11, 2012 | 04:14 PM
  #33
zigroid's Avatar
I found an old picture of my 383 from years ago on my cardomain page to compare your pistons. I had SRP 16cc dish pistons in that engine.
the look identical.
that engine, with stock sized combustion chambers, was about 10.5:1 with the thin mr gasket .026" thick head gaskets.
the engine was a dog. compression may have not been the main problem as there were other problems but it needed to be way higher. as was said earlier the C/R of a N/A LT1 should be around 11.5:1. Id sell the pistons and get flat tops. 5cc relief flat tops on my old 383 would have given me 12:1 with the mr gasket headgaskets, 11.7:1 with fel pro .039" thick head gaskets (if my memory is correct on the felpro gasket thickness).
Old Mar 11, 2012 | 07:33 PM
  #34
1961ba427's Avatar
While 10.5:1 may not be "optimum" on an all out pump gas LT1, I think you hit the nail on the head with the "other problems". That is stock compression ratio for these....so you could run whatever gas you wanted with your current pistons and no extra expense.
I don't doubt that alot of people push the limits with 12:1 on 93 octane....you'd better have the tune spot on to do so.
Old Mar 12, 2012 | 11:25 AM
  #35
Houdini's Avatar
The heads on my car are from CNC Heads, Pinellas Park, FL... picked them up in late 1999, I think they are decent heads. My number are in my sig.
Old Mar 12, 2012 | 11:40 AM
  #36
96capricemgr's Avatar
How about ET and MPH.
You have mystical LT4 heads, shouldn't we expect more?
Old Mar 12, 2012 | 01:53 PM
  #37
bowtienut's Avatar
I was gonna let him slide by with that one, since back in 1999 I would have been thrilled with 400 rwhp
If the whole topend came from CNC, I bet he's running a small cam. Their setups I've seen have been more street than strip oriented.
Old Mar 12, 2012 | 01:57 PM
  #38
HP numbers are interesting when a build is coming together, more than a decade later I think most objective folks want a bit more proof. We all know of engines that make HP but don't run well when actually asked to propel a car rather than a pair of rollers.
Old Mar 12, 2012 | 06:43 PM
  #39
fisherz28's Avatar
So what would you experienced guys guys recommend for a fun street car that will occasionnaly see the drag strip/auto x? Given the lower comp pistons and slight oil pressure issues im thinking a freshening up of the motor and new pistons are a good idea or am i just throwing money away?
Old Mar 12, 2012 | 06:49 PM
  #40
speed_demon24's Avatar
Depends what your idea of a fun street car is. I enjoyed my car the most when it had the crane 227 cam in it since it drove like stock and had gobs of off idle torque. The first thing I would do is have the heads gone through and try to find out as much as I could about them and see what the combustion chamber cc is for the compression ratio.
