Setting WOT AFR TunerCats.
Old Mar 18, 2012 | 10:56 PM
F0x Slaughter's Avatar
Default Setting WOT AFR TunerCats.
I understand WOT AFR is set by the
%Change to Fuel/Air Ratio vs Cool Temp
%Change to Fuel/Air Ratio vs RPM.
I read that its easier to 0 out your RPM table and then adjust accordingly.
How could you do that if at say 80 degrees its 19.2 and at 4000 rpm its whatever gives you 12.7. So at 92 degrees and 4000 rpm is going to be a different AFR.
