Need help with my budget build.
Any input is appreciated!
Thanks
A cheap rebuild. Than cold air intake, headers + exhaust, cam, gear (+ stall for auto's). should be good for 11.60's-12.30's @ 107-115mph.
I picked up an all forged 383 shortblock for less than many spend on 355's....just saying....something to think about.
This is ALL dependent on you doing most if not ALL the work yourself. Engine removal, tear down, pay to have it reassembled, then reinstall in the car etc. Dont forget you will need a tune at the end of all that.
Mine hasn't exploded the 10 bolt yet through a 6spd...but I'm only running 315mm street tires and it has a girdle. Just don't run slicks until you can afford to break a 10 bolt. There's always something to break, unless you drop well over 10K on the build initially with forged motor, rebuilt trans, and 9" ford rear. Just got to figure out which is most important to you to invest in first. The Best V8 Stories One Small Block at Time
Mine hasn't exploded the 10 bolt yet through a 6spd...but I'm only running 315mm street tires and it has a girdle. Just don't run slicks until you can afford to break a 10 bolt. There's always something to break, unless you drop well over 10K on the build initially with forged motor, rebuilt trans, and 9" ford rear. Just got to figure out which is most important to you to invest in first.You can follow the build here if you are interested.
http://camaroforums.com/forum/93-02-...-thread-68658/
