95 Lt1 engine harness into 94 Lt1 firebird
I recently bought a 95 engine harness and installed it in my 94 firebird. The motor cranks over. I know for sure there is no spark and i am lost as to what to do to gt this thing to work. I put my 94 harness back in hooked up injectors distributor, coil, map sensor and ground and it fired.
94 only has a c100. 95 has the c105 in addition to the c100. Make sure you move over the +12v to match the c100 supply from the fusebox on that 95 harness. Chances a
Re you are missing some 12v source that the c105 needs and you have not provided. . Then repin 210/220/230 as necessary based on diagrams on shbox site.
