Transmission problems ..
Old Mar 25, 2012 | 11:46 AM
tkelley's Avatar
Default Transmission problems ..
I own a 94 LT1 firebird, i recently had the transmission rebuilt. The guy took a LS1 tranny and put my rebuild kit and shift kit in it (TCI). Also put a 7500 rpm shaft. Now at 55 mph im at 3000 rpm. Is that normal? running stock stall. any help would be great, thanks!
Old Mar 25, 2012 | 12:29 PM
RamAir95TA's Avatar
Confused...an LS1 4L60E won't work with an LT1. Maybe I'm missing something here...
Old Mar 25, 2012 | 12:48 PM
tkelley's Avatar
its just the outer shell, all the internals are outta the rebuild kit, but my car came with a 4L60E tranny anyways
Old Mar 25, 2012 | 02:53 PM
Justin Hogan's Avatar
Sounds like its not going into 4th. if everything from your year was put in the case, it should be the exact same. my z28 is about 1500 at that speed.
EDIT: if you have gears in the rear it could be why its so high.
Old Mar 25, 2012 | 03:39 PM
tkelley's Avatar
also when i manually shift it nothing changes from 1st to 2nd but from 3nd to 3rd itll shift and then again from 3rd to Drive nothing changes.
Old Mar 25, 2012 | 06:49 PM
GreenBlood55's Avatar
Sounds like your only getting maybe 2 ...possibly 3 working gears. Def. not OD.
Old Mar 25, 2012 | 08:05 PM
tkelley's Avatar
yea i had a guy tell me that the stock shifter and linkage wont work with the tranny now and that i need a slap shifter with adjustable linkage
