To spray or not to spray???
but to answer your question, go with a wet shot. You can still blow it up if you are not careful and take necessary precautions. Good luck with your build
For a small shot like you're planning, I'd go with the wet kit. Simpler and less chance of a fatal error. Your fuel supply will be the most important part. If you don't dyno tune with a wideband, make sure you put a pressure gauge on it and watch it while you're spraying. I have no idea if that Granatelli pump is any good.
