slp 3pt SFC idea...
Old Mar 31, 2012 | 09:00 PM
my95LTwon's Avatar
Default slp 3pt SFC idea...
I just picked up some 3pt sfc's and a ds loop for my 94 Z Maybe it's because I work on euro-trash all day but I'm curious if anyone has ever fashioned up some protective under shields along with these? I'm thinking if I cut out some thin gauge steel to the same size as the OD of them and use the same mounting points it wouldnt look like crap. I would think it would help keep rocks/mud/general crap off the bottom of the car and possible improve aerodynamics? Any thoughts on this?
Old Mar 31, 2012 | 09:33 PM
RamAir95TA's Avatar
Alot of work for not much gain. Putting sheet metal under the car would protect the underbody but what's down there to protect? Are you going off-roading with your f-body? Not to mention it'd probably collect more road debris above it.
Aerodynamics won't be improved - just keep the front air dam on. That's all the aerodynamics you'd need.
Old Mar 31, 2012 | 09:57 PM
my95LTwon's Avatar
lol, yeah I just took the idea from the BMW's that have fully covered undercarriages. I do feel that keeping the rain and road grime off the brake lines and floor pans would be an advantage tho. Maybe not so much for aerodynamics....
As much as I try, sometimes you cant help but drive through some road construction or gravel roads. I also think it couldnt hurt the resale value either. If I was looking at a camaro and someone covered the underside of it I would have to be impressed.
