AFR head porting
Old Apr 3, 2012 | 08:03 AM
carlos64030's Avatar
Default AFR head porting
Dropped off a spare LT1 block yesterday at a machine shop to have a forged 383 built. I'm gonna have my AFR 195 heads ported. Who would you guys recommend do the head work? Does Advanced Inductions or Lloyd Elliot work on AFR castings?
Old Apr 3, 2012 | 08:19 AM
Puck's Avatar
GTP .
Old Apr 3, 2012 | 10:29 AM
AChotrod's Avatar
Lloyd does but I dont think AI does AFR
Old Apr 3, 2012 | 10:48 AM
gregrob's Avatar
Chad Speier if he will do it, or Craig at GTP.
Eric Brady
Old Apr 3, 2012 | 07:20 PM
joelster's Avatar
Are you still running the stock intake? What about the stock pcm?
Old Apr 3, 2012 | 10:17 PM
ElkySS's Avatar
iv got the name and number of a local porter that did an insane job on mine. put down 502 rwhp with a ported 195cc street head on a mustang dyno. if you want more info, just pm me.
Old Apr 3, 2012 | 10:50 PM
robsquikz28's Avatar
yes A.I and L.E will port AFR heads
Old Apr 4, 2012 | 12:29 AM
Puck's Avatar
What were the CC's after porting, ~210-215?
195 is an awfully small head for a 396, but I know the AFRs have a ton of meat that can be removed.
Old Apr 4, 2012 | 10:36 AM
Advanced Induction's Avatar
I appreciate your interest, but not anymore. It just isn't worth putting $ into them most of the time. Guys online tend to think aftermarket castings are invariably superior, and will typically pay enough for used aftermarket heads that you can be well on your way to a much better head - like the 200cc CNC'd GM LT1. Good luck with your project!
-Phil
Old Apr 4, 2012 | 03:12 PM
Ported LT4 intake and custom tuned PCM optimized for the last set-up. Will get another dyno-tune on the new motor.
Old Apr 4, 2012 | 05:22 PM
ElkySS's Avatar
they are 205cc now and im running a ported lt4 intake
