Oil Breakdown Tests
Old Apr 7, 2012 | 02:13 PM
Z28Camaro30Ann's Avatar
Default Oil Breakdown Tests
I have been doing some searches and all I can find are company propaganda and dump tests, but I am trying to find an unbiased oil test that compares several brands and also compares some oil filters. Basically, I have been TOLD that mobile is good...I have been TOLD that castrol is good...I want to see actual tests that PROVE who has the best oil and who has the best filter.
Preferrably full synthetic oil. Does anyone know of any accurate, reliable and unbiased tests like this?
Old Apr 7, 2012 | 02:31 PM
RamAir95TA's Avatar
Here's a good place to start. This site has been around a long time and provides some super good info.
Old Apr 7, 2012 | 02:59 PM
96capricemgr's Avatar
I am sure RamAir95TA just forgot to post this link.
http://www.bobistheoilguy.com/forums/ubbthreads.php
No way in hell he meant LS1tech was a good place, general automotive forums people blindly swear by brand loyalty based on marketing and decades old myths.
The link I provided actually has a section were people share Used Oil Analysis results which is exactly what you are asking for.
Old Apr 7, 2012 | 04:05 PM
96TransAmboosted's Avatar
Depends on what your looking for and what your driving, where your driving and how long you drive. what type of engine and how that engine is set up. i have been to seminars and automotive conventions for over 20yrs and have seen many tests ect. there is no one oil for everything, but in my opinion from working on cars for the past 20yrs, Mobile 1, and Valvoline for gas engines works very well to protect, and rotella for none gas engines, atvs and small engines with differ in there own ways
Old Apr 7, 2012 | 04:39 PM
BIGCAT7274's Avatar
i have never hurt a bearing with mobil 1 15/50. been 8.90's at 153
Old Apr 7, 2012 | 05:35 PM
RamAir95TA's Avatar
Hahahah, good call Dwayne. That CTRL+V eludes me again.
Old Apr 7, 2012 | 07:30 PM
WS Sick's Avatar
Come on guys Trop Artic is the stuff that empires were made on......
Old Apr 7, 2012 | 07:43 PM
gregrob's Avatar
Mobil 1 isn't very good at all. Its not even a true synthetic.
German Casterol 0-30 and Pennzoil Ultra are 2 of the best synthetics on the market right now for applications such as our cars.
Old Apr 7, 2012 | 09:33 PM
flyinZ's Avatar
Is Royal Purple any good? Or Castrol Syntec?
Old Apr 7, 2012 | 09:57 PM
gregrob's Avatar
RP is junk IMO
Old Apr 8, 2012 | 12:08 AM
nitrous2fast's Avatar
Hate to be the one to say it but... If you change your oil regularly you won't really have a problem with any decent oil brand. Conventional or synthetic.
Old Apr 8, 2012 | 12:17 AM
I am sure this is true, but different oils have different effects on an engine. I am just trying to find out what is the best because my car is only going to get the best. I am tired of people jumping on bandwagons and nut hugging specific brands. I want the facts. What oils perform well, what oils do not, what oild breakdown too soon, what oils do what they are supposed to without foaming or whatever. I want the real scoop instead of a guy who has used Castrol all his life trying to sell why Castrol is the best. I want the real facts so I can decide for myself what I want to use.
Old Apr 8, 2012 | 06:47 AM
It is true that with regular changes pretty much anything will do the trick BUT it is still good to see measured results because guys absolutely do pay $9 a quart for stuff that does not work as well as something that is $5 a quart.
Often "breakdown" is not so much the issue as is just the specific makeup of the oil, does it fall towards the thin or thick end of it's range vs. what does the engine design prefer along with what is the specific additive package.
After that an oil might be great for a weekend of racing but 4 months of driving will completely wear it out.
Also it is quite possible for a good oil to not work well in a particular engine family.
If someone wants to spend the money on an expensive synthetic it is good to see that person ask for measured results rather than the blind marketing loyalty usually expressed, just make sure you look at results for the same engine family. Also formulas change over the years so what was mediocre or great a couple years back might be great or mediocre now.
I used to spend a lot of time on the bobistheoilguy forum, back when I did M1 5w-30 always resulted in high iron content despite it's cult following in the LT1 community, same oil in a VW 1.8T at 15K miles looked awesome, quality product, just not as great for the LT1 as people assumed.
Old Apr 8, 2012 | 08:11 AM
Speedy's Avatar
A few years ago there was a guy on the forum who used to test the oil that came out of his LS1. He used to post the oil analysis online and a breakdown of what was in it. He found that German-made Castrol 0w30 oil was by far the best (it is a pure synthetic, you must read the label to ensure that it is made in Germany because some is made elsewhere).
The oil that came in second was Mobil 100% synthetic. Other oils didn't fare so well probably because even though they are advertised as synthetic, they aren't truly 100%.
There are some service stations that have the oil analysis machine. Look around and you can start performing the same tests yourself.
For the record, I don't worry about it. I have used Wal-Mart oil in my DDs for years, never failed a sniffer test, never burned oil, and only changed it every 6000miles. I use synthetic in my LS1 and LT1.
Old Apr 8, 2012 | 08:15 AM
FASTFATBOY's Avatar
http://www.frrax.com/rrforum/index.php?showtopic=1304
Old Apr 8, 2012 | 08:33 AM
That link requires a user name and password to access.
I don't have the link handy but years ago someone did an LS1 test of Amsoil Vs. M1 that was pretty interesting. Again though formulas change so while it was accurate then it might not be now. Some googling should turn it up.
Old Apr 8, 2012 | 08:49 AM
FASTFATBOY's Avatar
Here is another good read
www.ganoa.org/Motor_oil2.htm
Old Apr 8, 2012 | 08:59 AM
IronOutlaw's Avatar
Ive always read German Castrol was the way to go but cant find it so I run regular Castrol Syntec. Ive been reading good things about Pennzoil lately and know that they make a great two cycle Marine oil that I used to run religiously.
Old Apr 8, 2012 | 02:54 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
Autozone carries it. It's the 0W-30 European Formula Syntec. It will say Made in Germany on the bottle. They may have recently changed the name of Castrol Syntec to something else, but it should be fairly simple to figure it out with the aid of the internet.
Old Apr 8, 2012 | 04:38 PM
lt1-xjs's Avatar
Where do you get your info ? How is it not a true synthetic ? If it's not any good then why has GM used it as a factory fill on all Corvettes since 1993 ? Other company's use it as a factory fill also, Mercedes AMG, Porsche since 1996, The Aston Martin line, all Bentley's, the hot Nissan GT-R and even McLaren. I'm pretty sure Mercedes knows about the German Casterol. Mobil 1 must be ok.
