A.I. 21* HCI package
Old Apr 8, 2012 | 03:58 PM
Dave357LT1's Avatar
Default A.I. 21* HCI package
Well ive decided to pull the trigger and build AI 355. With the 21* heads can you run SA rockers? I imagine they mill the intake so all the runners line up when you get the package?
Would my SVO red tops be plenty injector for this combo?
Old Apr 8, 2012 | 04:14 PM
F0x Slaughter's Avatar
Injectors are based upon power.
What is your power goal?
What are the injectors rated to?
Why would you spend that money then run self aligning rockers?
Old Apr 8, 2012 | 04:35 PM
Dave357LT1's Avatar
I imagine this package would make 420ish rwhp. Injectors are 31.6 lbs with lt fuel pressure. And the reason i asked about the rockers is i already have comp ultra mags sa. I spin to 6800+ plus all the time with this combo and no issues.
Old Apr 8, 2012 | 04:59 PM
If you ask me you're asking for trouble. Walking a rocker is not good at all. I would just sell the rockers and get chromoly pushrods and guide plates and new rockers. Its cheaper insurance.
TFS chromoly pushrods are 100. Guide plates are like 30 bucks.
Those are two small. Get some 42lbs. Will give you some room to play with.
At 43.5psi 500bhp .5 BSFC you would need ~39lbs at 80% duty cycle. So 42s would give nice head room.
Those injectors would be at 100% duty cycle at 500bhp.
A 42 will be at 75%.
Old Apr 8, 2012 | 05:06 PM
gregrob's Avatar
Why would you run SA? That's going to be a VERY capable top end, don't neuter it with crappy parts IMO.
Good luck
Old Apr 8, 2012 | 05:35 PM
Dave357LT1's Avatar
Sounds like a plan ill get some nsa rockers. I have trickflow pushrods already if they are the proper length. Ill prob sell my motor to offset some of cost. What injectors are people having luck with?
Old Apr 8, 2012 | 05:38 PM
Speed Inc has some 42.5 injectors for 320 bucks.
Old Apr 8, 2012 | 05:39 PM
TravisMcGill2000's Avatar
Im runnin svo 30s with my 355 and trickflows. I think the 30s be plenty.
Old Apr 8, 2012 | 05:40 PM
Gizmo running mid 10s with 24s
Old Apr 8, 2012 | 05:49 PM
How much horsepower is he running?
385bhp would max out a 24lbs injector at stock pressure. If you bump psi a smaller injector acts bigger because more fuel is being pushed in per opening.
Old Apr 8, 2012 | 06:05 PM
96capricemgr's Avatar
Stock Eliminator cars are interesting to learn about but that does not mean it all translates to what the rest of us are doing, they spend a lot more to go fast with a lot "less".
While I know he does get away with such performance on such small injectors I believe the whole fuel system comes into play, not even just the pressure.
Old Apr 8, 2012 | 07:36 PM
Well i let yea know how mine turns out. Im running 30s on my le 21* 355 motor. Im goin for dyno tune this week.
Old Apr 8, 2012 | 08:41 PM
What is the horsepower you are guessing it will lay down?
Old Apr 8, 2012 | 10:12 PM
speed_demon24's Avatar
I made 430rwhp with 32lb injectors.
Old Apr 8, 2012 | 10:14 PM
What was the duty cycle for the injectors?
I'm going to say they are pretty damn close to 100%.
Gonna say around 96% roughly.
Old Apr 8, 2012 | 10:21 PM
Puck's Avatar
My stock cube H/C build had no problems at all with 30# SVO injectors. Its not a brick wall or end of the world at 80% duty cycle.
It's not like decades ago where injectors can't spray a proper pattern after 80%, modern injectors can still maintain a proper pulse at higher duty cycles.
Old Apr 8, 2012 | 10:26 PM
They will maintain the pattern but you have no room to grow. Plus it has a change of overheating the injector and could stick open. This is why you try to keep the injector around 80% cycle. So they don't fry. Use them in a pinch sure, but you want to properly size your injectors for your engine, just like a turbo. When you build a house do you go eh f code it will be to much money, or do you go lets build this to or beyond code because it will last.
Old Apr 8, 2012 | 10:57 PM
Not sure but my tuner said they were responding fine to changes. Uncorrected #"s were over 440rwhp that day too.
Old Apr 9, 2012 | 12:30 PM
Dave357LT1's Avatar
Well made the purchace today!!! Im now a AI Time to get out of the 13 sec club!
Old Apr 9, 2012 | 12:43 PM
transbird95's Avatar
Congrats man! Just wondering, were you only running 13's with the set up in your sig?
