93 to 97 block
Old Apr 10, 2012 | 07:53 PM
FAD2BLK93's Avatar
Default 93 to 97 block
Well i have a93 T/A and i am putting cam and heads on. And i realize after the breakdown its only a few more bolts to remove the motor which has 187k on it. But i have a stock sortblock in the garage with 52k on it. So my 93 parts should fit the 97 block right? ie: oil pump drive, timing cover, cam with the other cam pin, timing cover, intake from 93 should fit 97 heads, anything i missed? I know 93 cars are different in many ways but i think it all should work...thanks
Old Apr 10, 2012 | 08:02 PM
96capricemgr's Avatar
Knock sensors are a little different so swap it.
Make sure to remove the CPS reluctor and use the 93 hub or leave it and use the 97 hub.
Old Apr 10, 2012 | 08:38 PM
FAD2BLK93's Avatar
When i use the 93 front cover i will have to take the reluctor off anyway correct?
Old Apr 10, 2012 | 08:55 PM
RamAir95TA's Avatar
Use the 97 cover. It'll allow you to upgrade to the vented optispark. Leave the CPS in or block it off - it won't hurt anything. Either remove the reluctor ring and use your 93 hub or leave it in and use the 97 hub.
Old Apr 10, 2012 | 10:27 PM
FAD2BLK93's Avatar
I didn't get the 97 cover with the motor. I got a lt4 gm block off covers to run a carb. My old motor i beat the hell out of it and it stayed together just fine. Now i am putting another bullitt in the chamber and do not know much about it, i hope this on stays together cause im gonna beat the holy $ out of it too.
Old Apr 16, 2012 | 05:05 PM
Konman93's Avatar
Are you still running the 93 computer? Im not sure about T/A's but i know that 93 camaro were SD. If you are planing upgrading your car with performace parts, you should upgrade to a 94 - 95 computer with a MFS so you can tune it. You can tune a 93 computer with a chip, but have to buy a new chip every time you tune it.
