OBD2 LT1 to LSX OBD?
Old Apr 12, 2012 | 02:34 AM
Bigtoyz's Avatar
Default OBD2 LT1 to LSX OBD?
Is it possible to use a LSX computer on a LT1. I have a 97 LT1 and this tuning is driving me nuts. I have no one in the area to chat with if I have questions and it looks like LT1's are getting hard and hard to find info on. I have LT1 Edit and there is really no guides for that software that are very in depth. And I am using autotap for data scanner. My LTFT are -1.6-0 for both sides. And I believe that is trying to add a little fuel. And I am getting bad MPG 14 or so and it isnt that big of a cam I didnt think anyways 224/230 supercharger grind.
Old Apr 12, 2012 | 02:37 AM
gregrob's Avatar
http://www.eficonnection.com/eficonnection/24x.aspx
Old Apr 12, 2012 | 03:29 AM
Bigtoyz's Avatar
Thank You looks like that would be a good option.....kind of looks like a person could just as well do a FAST system also for the same price.
Old Apr 12, 2012 | 07:54 AM
95mysticta's Avatar
The price looks intimidating but if you build your own harness it can be easily done for around a grand or less. Then you sell all your stock parts and the price is even cheaper aslong as they are working. Do the math... it aint that bad and the gains so far have been awesome! Do some researching on some threads about it.
Old Apr 12, 2012 | 01:45 PM
WS Sick's Avatar
I had tha same problem, but I went backwards tech wise, I put an OBD1 computer in my 97 then used datamaster and tunercats.
What I hated, in my local area, is noone wants to even mess with an LT1 on the dyno, past just dynoing it. My best option in area is to drive (or haul) over 100 miles to Tulsa to have Ed Wright do it.
Old Apr 12, 2012 | 11:33 PM
MEAN LT1's Avatar
were you located?
Old Apr 12, 2012 | 11:40 PM
sandman2100's Avatar
WS Sick
Garage is empty, add now
Trader Rating: 0
What gains are there when going to 24X? Aside from the obvious opti deletion...
Old Apr 12, 2012 | 11:41 PM
WS Sick's Avatar
Yep I'm in Kingfisher....
Old Apr 13, 2012 | 11:16 AM
quicksilver383's Avatar
Would you consider tuning it yourself while on the dyno? You have tunercat.
Old Apr 13, 2012 | 01:06 PM
WS Sick's Avatar
Yes that is what I do, I didn't mean to give the impression that I don't do it. I just can't find any dyno guys that tune LSXs all day long to mess with mine.
Old Apr 21, 2012 | 09:58 PM
Bigtoyz's Avatar
Yeah I figured out is is same price just to goto FAST also.....with a few more options for forced and NOS also that other I do not think has. I thought around a grand I would do the conversion to LSx but I dont want to mess with building a wireloom either. For the neat freak I would be on it ...it would take me 2 weeks prob.
Old Apr 21, 2012 | 10:01 PM
Bigtoyz's Avatar
But I am slowly figuring this LT1 Edit out though. I ended up upping constant to 54 to get it lean enough for it to bounce between rich and lean for start up. But then when starting it up for first time for the day it was hard starting. So after some pondering I thought of PE by Temp raised it by 5 from -40 to 44 and bam starts how it should now just barely hit the key and bam running.
Old Apr 21, 2012 | 10:17 PM
69gto96z's Avatar
Originally Posted by sandman2100
WS Sick
Trader Rating: 0
As far as I have seen thats about it, I haven't seen anybody claiming HP increases at all. And the fact that you can have it dyno tuned anywhere that LSx's get tuned.
Old Apr 21, 2012 | 10:38 PM
Thanks, that's what I figured!
Old Apr 22, 2012 | 07:47 PM
IllusionalTA's Avatar
I'd drive to Ed! Stand up guy!
