Change water pump from the top or bottom??
Old Apr 12, 2012 | 01:24 PM
BLK93TA's Avatar
Default Change water pump from the top or bottom??
I need time change my water pump out but wanted to get any tips and also which way I need to attack it! Thanks a bunch!
Old Apr 12, 2012 | 01:25 PM
BLK93TA's Avatar
It's time not I need time lol
Old Apr 12, 2012 | 01:35 PM
Puck's Avatar
Its right there on top lol. Piece of cake.
Old Apr 12, 2012 | 02:50 PM
BLK93TA's Avatar
Yeah looked like take the intake off and it's right there
Old Apr 12, 2012 | 02:58 PM
93M6Formula's Avatar
Pretty simple, there are 6 bolts total on the pump. Just be sure to drain coolant out of the radiator first and be sure when you pull the pump off not to get any coolant on the Opti or you will have more problems.
Old Apr 12, 2012 | 04:01 PM
lethal bird's Avatar
Super simple shouldnt take more than 30 min.
Old Apr 12, 2012 | 04:07 PM
Rob94hawk's Avatar
I think when you're stock with all the emmision BS it's a little more than 30 minutes. I recall having to remove the air pump and bracket and you have to get underneath to do it. But that was over 15 years ago.
FYI, try not to get any coolant on the optispark distributor! Stuff rags around it.
Old Apr 12, 2012 | 04:17 PM
Shouldn't be as difficult on a 93 since the AIR pump is located on the frame rail as opposed to 94-97s mounted on the front of the motor.
Old Apr 12, 2012 | 04:22 PM
Rob94hawk's Avatar
Interesting. Had no idea.
Old Apr 12, 2012 | 04:57 PM
Remember the 93 LT1 is the bastard child lol, so there is plenty of differences compared to other years.
Old Apr 12, 2012 | 05:03 PM
BLK93TA's Avatar
I'm proud of my 93
Old Apr 12, 2012 | 05:17 PM
Yep.... But your right i forget about air/egr I haven't had it in so long. So add another 15 min with taking that junk off.
