LT1 355 build questions
Probe .030 forged pistions with plasmolly rings
5.7 H-beam rods with arp L-19 upgraded rod bolts
3.48 forged egale crank
LE cam 224/230 .573/.568 112 LSA. – 1700-6100 RPM thats emissons legal since im in commieforina
Sealed Power performance Bearings
LT1 195cc Trick flow assembled Heads and gasket and bolt kit
stock intake that is port matched with heads
58mm throttle body
accel 30Lbs injectors
eletric water pump
SlP Headers with hi flow cats
Here are the questions:
i was wondering since im not running a stock water pump what is the best timing chain set with part number? i have a 1993 timing cover so i think i should be fine clearance wise.
How much does splaying main caps run on average? and last questions is about optispark. is it worth keeping it and retro fitting to LTCC set up
thanks everybody
any good single roller for a SBC should be fine for a timing chain... At least i think so...
Double roller might make you clearance the cover... maybe..
Was your stock crank bad? Just curious about the stock stroke forged crank purchase. A good stock crank and the ARP 8740 rod bolts would be fine at the described power level also.
If buying a crank why buy stock stroke?
If buying rods why buy 5.7?
If doing such a mild build why spend the extra on the L-19 bolts?
If you have the stock crank I would reuse it and get a 6.0" forged rod Scat or Eagle with the regular ARP hardware, pick an appropriate piston. Just saved $600 that you could put into making more power with head porting.
If you really want an aftermarket head I would consider the Trickflow 21degree WITH PORTING, the small chamber will help with compression. If that is too much money then have the stock heads ported, I would think this would be easier come inspection time too.
