Oil Viscosity Question
(10w30) and Fram Guard Filter. Today, she runs warm at stoplights. Is the 10w30 too thick?
Thanks.
What oil/weight were you using before?
I HIGHLY doubt a small change in oil weight could cause an engine to run warmer. There's probably another explanation, perhaps just coincidence.
This is my first LT1, so I was thinking that i should've purchased 5w30 instead.
d for this engine sent to some places overseas so you concerns about 10w-30 are completely unfounded, hell if you look at the owner's manual it will even say 10w-30 is OK for over 0F temps outside. 5w-30 is spec'd for CAFE reasons not because it is critical to the engine.
Fram filters are bottom of the barrel but that isn't your problem either.
Maybe you knocked a wire for a fan loose or knocked off the airdam pulling it up on the ramps or something else that is affecting cooling.
They say there is no such thing as a stupid question but this comes damned close.
As I had already covered 30weight is a RANGE not a specific measurement.
Here is a post with a VOA of German Castrol 0w-30. CST @ 100C is 11.78
http://www.bobistheoilguy.com/forums...gonew=1#UNREAD
Here is a VOA for M1 sypersyn 5w-30 CST @ 100C of 10.19
The range for 30weight is 9.3-12.49
I just looked for the most recent VOAs on each oil I have seen M1 test down in the 9s and GC test in the 12s
Some of the best measured results we have for LT1s is GC 0w-30.
IMO the reason you don't see 0w-30 spec'd often is for one it is synthetic only, and you don't see 10w-30 spec'd because they want the thinner startup to reduce startup emissions.
LT1s sent overseas got 15w-40 in some cases and the places that get really hot also tend to get fairly cold at times.
I run 0w40....helps at startup and has a good base weight.
I could see why some guys get confused and maybe scared of going lighter after being at a higher range for a long time. After all if the base weights of all these oils didn't play some kind of an influence on the bearings then 20w50 dino would never raise pressure on an old engine. So some of you guys are off on attacking others for having some caution and questions.
If the engine is a well seasoned over 100K'er on 10w30 it may not be so great to go to 0w-20. Sure it'll work....but still not so great for various other reasons including the wear related clearances.
