random missfires
180k+
just replaced plugs and msd coil, msd opti, and msd wires..
but it supposedly still doing it...
the below is messed up, we temp fixed it.
would un-metered air going into the tb from a hole in the below cause this?
When it starts missing, try unhooking the o2 sensors. They could be going bad. Also, check the coolant temp sensor in the water pump. That and a faulty knock sensor can both cause spark retard.
check for burnt wires first... being it does it up hill tells me a wire is moving and touching the header/manifold...
