radiator ?
Old Apr 17, 2012 | 03:30 PM
TravisMcGill2000's Avatar
Default radiator ?
Will a ls1 radiator work on my 94 ta. Mine is leaking and i found good deal on a ls1 rad. Thanks
Old Apr 17, 2012 | 03:36 PM
am_muscl's Avatar
i know you can use an lt1 radiator in an ls car but I'm not sure about the other way around. Sorry for not helping but that's just what I found doing a search
Old Apr 17, 2012 | 04:13 PM
It has the cross over port. Only thing i can see it dont have is the small port on the lower driver side. What is that port for?
Old Apr 17, 2012 | 04:30 PM
speed_demon24's Avatar
The ls1 radiator would be a downgrade for you.
Old Apr 17, 2012 | 04:33 PM
FormulaJoe's Avatar
Lower drivers side goes to throttle body
Old Apr 17, 2012 | 04:44 PM
Its goin to the water pump. I know the lt1 is better but i dont think ill have problem coolin with ls1. I dont dd my car. Its 80% track 20% street. Do yall think it will work.
Old Apr 17, 2012 | 05:55 PM
RamAir95TA's Avatar
Cooling at the strip is just as imperative as cooling on the street. I'm sure you could make it work, but the LT1 radiator is superior.
