Rocker Arm Conversion Question
i see the rocker arm nut thread length is .67 inches. does it screw deep enough into you rocker arms or is it a bit shallow?
i had to shim my old 3/8 setup because it was too shallow.
longer ones I used with the Dart castings. I ended up using taller studs.
Most people will never run into that issue.
In retrospect, I should have machined he heads for shaft-mount Jesel rockers while I had it apart.
It really would have simplified geometry for me.
