Is my dampner on all the way?
Old Apr 20, 2012 | 06:18 PM
chas010's Avatar
Default Is my dampner on all the way?
I think im losing it... i keep thinking my dampner is sticking out further thsn it was before the cam swap. There is about 3/16s between the msd opti cap and the back of the balancer. I remember it being closer than that .
Old Apr 20, 2012 | 06:42 PM
Rob94hawk's Avatar
Is this a Fluidampr? Because this is what I have.
Old Apr 20, 2012 | 06:44 PM
chas010's Avatar
Ati super dampner.
Old Apr 20, 2012 | 08:23 PM
Rob94hawk's Avatar
If it's seated as far as it can go against the sprocket then you should be good. But, it does look like it is NOT seated all the way.
Is the engine on a stand?
Old Apr 20, 2012 | 09:23 PM
fex77k's Avatar
Mine looked the same way but it is definately seated.
Old Apr 21, 2012 | 03:01 AM
chas010's Avatar
Thanks fex77k, this one is seated also but has the shim behind it. I was almost tempted to pull that shim out.
Old Apr 21, 2012 | 05:29 AM
joelster's Avatar
How does the belt line up on the alternator?
Old Apr 21, 2012 | 06:24 AM
gcouse7's Avatar
if the belt is lined up, it is good.
Old Apr 21, 2012 | 06:25 AM
BIGCAT7274's Avatar
stop that. your taking all the fun out of the guessing.
you can also trq the bolt then take a block of wood and hit it with a bfh and recheck the trq on the bolt. if the bolt turns its not seated.
Old Apr 21, 2012 | 01:29 PM
93v8clone's Avatar
u dont ever hit the dampner with anything lol thats how ya wreck bearings wow man
Old Apr 21, 2012 | 01:35 PM
RamAir95TA's Avatar
Terrible idea.
OP - it should be obvious when it is seated fully if you're using an install tool.
Old Apr 21, 2012 | 02:56 PM
fex77k's Avatar
That's what mine looked like without the shim.
