Whats that silver box under the dash
Old Apr 26, 2012 | 11:57 AM
wrd1972's Avatar
Default Whats that silver box under the dash
What is that silver metal box with wires under the dash between the steering column and the driver door?
Old Apr 26, 2012 | 12:01 PM
SS RRR's Avatar
Village Troll
It's a black box. Big brother is watching!
www.shbox.com
Old Apr 26, 2012 | 12:30 PM
pillarpod's Avatar
there trying to trick you, thats why its silver
Old Apr 26, 2012 | 01:15 PM
jb442's Avatar
ABS control module. The GM diagrams really don't show it in the correct location. From the diagram you'd think it was under the seats!
Old Apr 26, 2012 | 02:01 PM
RamAir95TA's Avatar
Also known as the BCM, or body control module. It's designed to keep you from shitting yourself.
Old Apr 26, 2012 | 02:08 PM
ahritchie's Avatar
Flux capacitor
Old Apr 26, 2012 | 02:50 PM
DisasterFormula's Avatar
I thought BCM was introduced in 96.
Old Apr 26, 2012 | 03:44 PM
wrd1972's Avatar
ABS module huh..........
Old Apr 26, 2012 | 05:32 PM
SS RRR's Avatar
Village Troll
I also thought it was located behind the glove box?
Old Apr 26, 2012 | 05:36 PM
Rob94hawk's Avatar
Pull it out. Let us know what happens.
Old Apr 26, 2012 | 06:49 PM
RamAir95TA's Avatar
I just tore down a buddies dash and replaced the wiring with a Painless harness. Pulled out and ID'd every module - the BCM is on the driver side tucked up in the corner. It's a silver box with a pretty big connector (2x16).
There are several other modules under there, some located on the passenger side, some on the driver side. RAP, airbag, TDM, BCM, etc.
Old Apr 26, 2012 | 07:51 PM
And what year was your buddy's car?
Old Apr 26, 2012 | 07:55 PM
RamAir95TA's Avatar
Old Apr 26, 2012 | 08:19 PM
Alright, research shows that it should be the airbag control module and does have a black box function that records sensors, throttle position, braking force, etc., and shows it back for the 5 seconds before impact.
Old Apr 26, 2012 | 08:21 PM
And I confirmed that they did not get BCMs until 96.
Old Apr 26, 2012 | 08:27 PM
RamAir95TA's Avatar
I am looking at my factory service manual (for my 95) and it distinctly shows a BCM, location, diagnosis, etc. Location description says "above driver side kick panel" and there's a pretty diagram that shows its exact location - precisely where the OP says it is.
The OP says it's SILVER, not BLACK. The BCM is silver.
Old Apr 26, 2012 | 08:39 PM
I said it serves a black box function, not is a black box. Have you ever seen an airplane black box? They aren't black. They're bright fcking colors like orange and yellow to facilitate finding them. Yeah, that's right. Black boxes are fcking yellow.
Old Apr 26, 2012 | 10:05 PM
wrd1972's Avatar
LMAO.
Its definitely silver.
Old Apr 26, 2012 | 10:17 PM
shbox's Avatar
It's the EBCM (Electronic Brake Control Module) not BCM (Body Control Module) that on the left side of the dash.
The BCM is on the right.
Both are silver, IIRC.
Old Apr 27, 2012 | 05:57 AM
RamAir95TA's Avatar
So I was half right...
