Need AFR. for my LT1
Old May 5, 2012 | 10:39 AM
  #41
Jason94z's Avatar
Originally Posted by F0x Slaughter
Stock Pressure is 43.5psi. LSx pressure is 58psi.
Thank you
I think my new gauge is calibrated wrong it is reading 20psi unhooked. Hmm.
Old May 5, 2012 | 11:15 AM
  #42
F0x Slaughter's Avatar
It should be ~43 with key on car off. Idle it should drop down 3 - 7psi so anywhere from 36 - 40psi at idle.
So if its reading 60psi at idle and 20psi not hooked up. Its obviously off by 20psi.
When you bump up pressure a smaller injector acts like a bigger injector because when it opens more fuel is flowing through because there is more pressure.
Old May 5, 2012 | 01:46 PM
  #43
whytryz28's Avatar
36 is kinda low obviously not enough pump if it hits that.
Old May 5, 2012 | 02:26 PM
  #44
Jason94z's Avatar
I just dont know why my hypertech guage is starting 20 PSI high. Is it broken?
Old May 5, 2012 | 02:34 PM
  #45
Probably because its hypertech? Commonly called HyperCrap.
Old May 5, 2012 | 04:10 PM
  #46
mack's Avatar
Correction to my numbers:
404 RWHP
440 RWTQ
Old May 5, 2012 | 04:28 PM
  #47
Puck's Avatar
How much it drops from motor off/key on to idle depends on the cam.
Old May 5, 2012 | 04:40 PM
  #48
True.
Due to the fact of different cams creating different vacuums.
Old May 6, 2012 | 05:08 AM
  #49
LilJayV10's Avatar
Originally Posted by gregrob
Maybe if we knew what in the hell you were talking about.
This is the most intelligent post so far in this thread.
