Engine oil recommended by builder 20w50
I've been running 20w50 ever since but now am questioning it. The builder is not around anymore - this was like 7 years ago. Could I do a test or just keep running th 20w50?
How could I verify the oil required? Is there a way?
Anyone else have a looser engine that takes 20w50?
Maybe you could try a middle ground like a 15w-40 and have a Used Oil Analysis done? There are usually local places that can do it as it is common with fleet vehicles and diesel stuff with big sumps(expensive to change gallons if the oil is still fine) but on the internet Blackstone Labs is popular.
I just wondered ... if I really need that heavy an oil. Maybe I"ll try one step down like 96capricemgr suggests. I already bought my oil for this change.
Also another question: how many litres does the LT1 take? I have a windage tray and am now questioning whether the angle of the dip stick is correct. So I'd love to fill it with how much it's "supposed" to have, and then check the dipstick and see where it reads.
When I was young I didn't care. Now that I'm bringing this car back out of storage new questions need answering.
often oil pump drive gear will wear IF the person put in a HV oil pump AND does NOT have wider bearing clearances. pump/gear is strained by trying to push thick oil through stock bearing clearances.
often wider bearing clearances + HV pump + thicker 20-50 oil.
Porsche has done this for years on the 911
IMO it is inappropriate to setup a modest street build for 20w-50, too much load on the drive, goes into bypass reducing cooling volume across the bearings at a lower rpm. There is just no reason for it.
For wilder engines seeing more load maybe it is appropriate, or as noted in another thread it can be used to firm up hydraulic lofters.
I have run 20w-50 for a short time when trying to figure out an oiling issue, in the end I put a different windage tray in and a pan baffle since it was only $5 and went back to Xw-30 oils and all was good. I think part of the "issue" though was the spot I was using for a street test area was a slightly uphill and curved rural highway onramp. The current acceleration rates of the car combined with the grade and lateral force seemed to combined to cause the trouble. I hadn't seen the high rpm pressure drop on level ground but an aftermarket tray and pan baffle was all of $30.
Your stroker makes decent power if it were a cam only setup, the average heads/cam setup is much more powerful.
IMO some volume internet engine builders spec excessively thick oil so they can just build every quickly and sloppily, if the clearance tolerances are loose and you give it thick oil variations in tolerance are less likely to eat a bearing or such.
Building an engine with clearances for 5w-30 is a bit less forgiving, you have a tapered journal and happen to measure the small spot the high side eats the bearing. It requires more attention to detail and TIME to build a tighter clearance motor.
There is evidence to suggest the internets highest volume LT1 vendor uses power tools to assemble the rotating assembly, and a lot of evidence to suggest they don't inspect much before slapping it together.
