Changing timing cover seals with engine out?
Old Apr 29, 2012 | 09:59 AM
derek3.4's Avatar
Default Changing timing cover seals with engine out?
So I've been trying to research this and all the threads I've found seem to only cover the topic with the engine in the car with the trans in a high gear(m6) or a chain/strap(A4) keeping the crank from rotating while removing the hub and such. Any suggestions with the engine out?
Old Apr 29, 2012 | 10:03 AM
jasonz28camaro's Avatar
use a screwdriver to wedge the flexplate against the stand or block and the crank wont turn.
Old Apr 29, 2012 | 10:16 AM
derek3.4's Avatar
sounds good. I'll give it a try. Thanks
Old Apr 29, 2012 | 11:42 AM
FAD2BLK93's Avatar
X2 been doing that for years.
